March 4, 2010, 19:37 |
Fluent UDF help!!!
Hi everyone
I am trying to model a moving sphere in hypersonic flow. I want the sphere to move according to the forces in experiences due to the incoming flow. It is a 2D axis symmetric case and hence i want the sphere to move in only one direction, basically 1 DOF motion. Below is my UDF, it complies alright, but when i try to run it fluent gives me a segmentation violation error, i am only defining my sphere as a rigid body in the zones with the UDF and have not defined anything else, i am using the smoothing parameter for my dynamic mesh. Any help will be much appreciated #include "udf.h" static real v_prev = 0.0; DEFINE_CG_MOTION(sphere,dt,vel,omega,time,dtime) { Thread *t; face_t f; real NV_VEC(A); real force, dv; /* reset velocities */ NV_S(vel, =, 0.0); NV_S(omega, =, 0.0); if (!Data_Valid_P()) return; /* get the thread pointer for which this motion is defined */ t = DT_THREAD(dt); /* compute pressure force on body by looping through all faces */ force = 0.0; begin_f_loop(f,t) { F_AREA(A,f,t); force += F_P(f,t) * NV_MAG(A); } end_f_loop(f,t) /* compute change in velocity, i.e., dv = F * dt / mass velocity update using explicit Euler formula */ dv = dtime * force / .000756; v_prev += dv; Message ("time = %f, x_vel = %f, force = %f\n", time, v_prev, force); /* set x-component of velocity */ vel[0] = v_prev; } |
Display Modes | |
Using Fluent with a UDF frm a remote m/c | aarti | FLUENT | 2 | September 11, 2008 20:53 |
problem loading UDF in parallel fluent | Tim | FLUENT | 12 | July 12, 2008 13:59 |
HELP! Fluent UDF Iterate error | Sam | FLUENT | 2 | July 10, 2008 22:29 |
UDF problem caused by various version of Fluent | Yurong | FLUENT | 3 | January 15, 2006 11:57 |
Can somebody send me a Fluent 6 UDF manual?? | KKLAU | FLUENT | 4 | April 14, 2004 17:37 |
