Home > Forums > Software User Forums > AVL FIRE
Running FIRE on PLATFORM LSF
Old   May 28, 2014, 07:06
Default Running FIRE on PLATFORM LSF
taoyikai is on a distinguished road
hi
recently I am trying to run FIRE on high performance center whose system is LSF.
Does anyone have the experience to do so? If so, it would be very appreciating if you could share your experience with me.
thx
taoyikai is offline   Reply With Quote
Old   May 29, 2014, 02:26
Changdeo Gaikwad
chang.gaikwad is on a distinguished road
We use the LSF systems to run FIRE jobs on HPC. But all setup is done by IT team.
chang.gaikwad is offline   Reply With Quote
Old   May 29, 2014, 04:17
thx for reply
besides, do you run FIRE on specific nodes? Or the LSF system will select the suitable node for you ?
Old   May 29, 2014, 05:22
Changdeo Gaikwad
In our setup, LSF first tries to select full ideal nodes (based on number of CPUs/cores requested). If required no of full ideal nodes are not found then LSF takes partially occupied nodes.
We do not run FIRE on specific nodes but let LSF to decide that. But yes, we have two queues of nodes (x cores per nodes and y cores per nodes) and we mentions (to LSF) which queue to be used.
Old   May 29, 2014, 07:01
it seems so wonderful, and your discription really meet my situation.
Could you tell me the terminal command that you use when you submit the job?
And it would be so appreciating if you could ask the IT team about the setting of the LSF system and the software FIRE. If you dont have so many spare time, just give me the contact information of the IT team ,and I would turn to them for further information.
thx for all
Old   May 29, 2014, 08:13
Changdeo Gaikwad
We don't use the terminal command. We have online form where we mention the project name and location, case to run and number of CPUs desired. That's all.
If you want more information on LSF then why don't you get in touch with the software vendor itself? That will be quick and authentic.
Old   May 29, 2014, 08:32
I contact the avl local support, but they dont know about LSF. everytime I ask them about the LSF, they turn to the headquarter. The feedback require so long time with so little information.
Back to our discussion, you run FIRE on HPC, so you have to login the host node (maybe login node), and then deal with FIRE right?
Old   May 30, 2014, 02:22
Changdeo Gaikwad
That I don't know.
Old   May 30, 2014, 03:28
would you please give me the email of your it team? So that I can contact them for more information
Old   May 30, 2014, 03:40
Changdeo Gaikwad
I am sorry, I can not give that.
Old   June 5, 2014, 01:21
thank you all the same
CFX parallel jobs on LSF Dominik CFX 4 June 22, 2022 13:18
how to run fire on LSF taoyikai AVL FIRE 0 May 21, 2014 05:21
CFX11 + Fortran compiler ? Mohan CFX 20 March 30, 2011 18:56
Suse10 FoamX problem frank178 OpenFOAM Installation 6 January 14, 2010 04:18
Statically Compiling OpenFOAM Issues herzfeldd OpenFOAM Installation 21 January 6, 2009 09:38
