March 13, 2000, 06:32 |
Convert AutoCAD-files
Does anyone know how to convert dwg-files into a format that prostar easily can read? dwg is the format of AutoCAD.
Sincerely, Lennart Wern, Swedish Meteorological and Hydrological Institute, |
March 14, 2000, 04:52 |
Re: Convert AutoCAD-files
hi lenn I'll suggest one method,see if it works. Convert all the curves in your autocad dwg to splines and save it. Then if you have any solid modelling package import this dwg file into that pacakage and then convert it to iges format which is acceptable by Star-CD.
g.luck satish |
March 15, 2000, 12:59 |
If your version of AutoCAD can export files as an STL file then prostar should read them straight in.
March 16, 2000, 02:07 |
Hi J Reed,
I think that you must create one file for each solid in AutoCAD, not one file for all solids. We have many many solids in the dwg-files. Another problem is that we do not have AutoCAD, we just got those dwg-files that we have to convert to a format Prostar can read. Sincerely, Lennart Wern, Swedish Meteorological and Hydrological Institute |
October 24, 2000, 10:57 |
hi lennart,
export your autocad file as an iges (or igs) file. autocad should produce a "filename.igs" file. paste the file into the directory you are currently meshing from and use the command: iges filename.igs this should get your drawing in as a bunch of splines. dave |
July 23, 2022, 06:28 |
Convert AutoCAD file
amara albert
You can easily convert the AutoCAD file with the DRS AutoCAD DWG Converter Tool. This converts the AutoCAD file very quickly. download this free version.
[General] Convert Tecplot DAT files to ParaView redable one | B. R. Guirguis | ParaView | 7 | September 8, 2023 06:38 |
Importing autocad files into GAMBIT | Shanti | FLUENT | 3 | June 6, 2006 06:07 |
convert star files to fluent (couples) | azmir | FLUENT | 6 | May 6, 2004 04:56 |
How to convert .dwg into .igs files? | Juan | CFX | 3 | November 25, 2003 06:45 |
AutoCad/Iges files/Solidworks | Roued | Main CFD Forum | 3 | November 28, 2001 08:43 |
