October 24, 2002, 08:38 |
Post data
Hi I want to post process the shear rate in my simulation i pressume to get such a value in my .pst file i need to use the POSDAT sub-routine, have you any idea of the coding needed to get SECINV out? joel
October 28, 2002, 09:54 |
Re: Post data
You may define a passive scalar and use subroutine scalfn.f for the calculation of the shear rate (Option "User" for the solution method of the scalar).
November 4, 2002, 05:39 |
Re: Post data
so in the user coding i just need to type secinv? there is no example coding under star as with most of the sub-routines.
November 4, 2002, 05:58 |
Re: Post data
You have to calculate the value you need yourself by using the derivations dudx, dudy, ...
SECINV is (normally) only accessible in subroutines VISMOL and VISTUR. |
vertex post data | george | Siemens | 1 | January 6, 2007 14:31 |
post data | starcd_learner | Siemens | 0 | February 1, 2006 11:24 |
manipulating post data | Brad | Siemens | 1 | June 13, 2002 10:03 |
Import data into CFX-Post | Jens Chr. | CFX | 5 | May 14, 2002 11:59 |
Boundary Post Data | Chengxuan Fu | Siemens | 1 | June 4, 2001 11:50 |
