moving mesh problem
Old   January 12, 2005, 11:26
Default moving mesh problem
walid
I have a moving mesh for SI engine. When I resume the moving mesh in es-ice, I do a "create ice template" but in the es-ice window I have this response: "The file 'valve0x.dat' is not readable, so the temporary file 'filename' has been created from its saved image. "(x=1,4)" After that, when I create the star setup (Ice template, star) I have the following warning: "63 vertices will be held fixed or will be translated with the piston". But still, it creates the "es-ice.PNL" The problem is in prostar, it cannot compile the model. Even if I run the model without calculation, that is, even if I just run the mesh using the adequate switch (in the menu "switches and real constants") I still have this problem. What can I do to resolve this problem? Could the problem be originating from the error explained above? (The file 'valve0x.dat' is not readable) And if so, how to rebuild them? For information, I create the star setup for the prostar version 3.2 my own version is 3.22 Thank you in advance for your help.
Kind regards.
Old   January 15, 2005, 18:59
Default Re: moving mesh problem
Gudrun
I'd say that you, as a first try, should make shure that you have your valve01-04 files available in the running directory, as these describe the valve motion, and thus are essential for the mesh movement.
The valve-files are simply 2 columns of crank angle and lift for each pair of valves, so you shouldn't have a problem "rebuilding" them as long as you have info about the cam.
Old   January 17, 2005, 04:27
Default StarCD tutorials
narendra kumar m
Old   February 10, 2005, 08:55
Wendy Tjia
Dear walid,
Could I make a correspondence with you personally furthermore? Please let me know if you do not mind regarding my need to make a discussion with you.
Regards,
Wendy Tjia
Old   March 8, 2005, 14:20
Default Re: StarCD tutorials
kapil
Can u plz send me the star cd tutorial pdf file or ny other readable format i would be very grateful to you ! kapil
Old   March 8, 2005, 23:37
Default Re: prePDF in fluent
narendra
i am modeling comustion problem but facing problem with prePDF in fluent i dont know how to prepare prePDF plz can u help how to prepare prePDF and how to input in to fluent
Old   April 1, 2005, 17:31
jair meza
can u help how to prepare prePDF and how to input in to fluent.
Problem with moving mesh Sully FLUENT 7 September 11, 2008 00:38
Moving Mesh Problem Rashad FLUENT 0 August 28, 2006 04:31
moving mesh problem eos Siemens 4 January 27, 2006 20:42
Moving Mesh PROBLEM Arnab Siemens 10 October 30, 2004 02:10
Moving mesh problem Jan Majer Siemens 2 June 10, 2003 04:19
