Steady state Aeroacoustic simulation
Old   May 24, 2005, 20:36
Default Steady state Aeroacoustic simulation
Niten Mistry
I am using the aero-acoustics module available Star-CD V3.22 to run a steady state aeroacoustic simulation around a car side view mirror using high Re k-e model.
After the simulation converges, 1000 cells have been identified as acoustic sound sources. However I am unable to retrieve this data from the post file or from the post processing module. Does anybody have any advice on this?
Thanks in advance
Niten
Old   May 25, 2005, 04:02
Default Re: Steady state Aeroacoustic simulation
Alex
Niten,
The Lilley source term is stored in the post file (getc aals).
Alex.
Old   May 25, 2005, 05:38
Niten Mistry
Hi alex,
When i type in that command, it simply says ' **error-aals is not a valid cell vecotr/scalar label.' Is there any other way of extracting the data?
Old   May 25, 2005, 05:52
Alex
When you load the .pst file, look in the get data panel in the STARGUIde to see if one of the options scalar options is the Lilley source. If it isn't there, then it hasn't been store on the post file.
If it's not on the post file, then either you didn't turn it on, it didn't get calculated correctly (check STAR output for any errors) or it's a bug and you should call support.
Alex.
Old   May 25, 2005, 06:09
Niten Mistry
Hi Alex,
I have run the simulation for a second time, and have definitely specified for the aeroacoustic equation source to be turned on. The info file reveals no errors in the convergence for the simulation, yet I am unable to retrieve the Lilley source from the post file. Any more suggestions?
Thanks
Niten
Old   May 27, 2005, 07:02
sankar
If u are using STAR V3.22 Aeroaccoustics methodology is clearly described in prostar users guide. after loading post data. in scalar variables Accoustic source will come and you can get the data. and you can plot also.
rgds
sankar
Flow-3D for Steady State Simulation CK Main CFD Forum 5 March 2, 2021 06:29
convergence for transient/steady state simulation Gab CFX 36 August 20, 2012 12:55
material property in steady state CHT simulation NVSD BABU CFX 3 February 25, 2009 00:58
steady state simulation timesteps amine CFX 4 March 17, 2008 10:29
steady state simulation manoj FLUENT 1 March 20, 2004 07:15
