error reading file
Old   September 20, 2005, 19:43
Default error reading file
limingtiger
when i finished transient simulation, i try to read the pstt, but the error #250 happaned. i ran the trasient simulation after i have finished steady state running. how can i settle the problem?
Old   September 21, 2005, 09:13
Default Re: error reading file
Hubert Janocha
It seems to be that your *.pstt file exeeds the size of 2 GB. Belonging to 32bit OS there is no remedy for this.
Instead of using the pstt file define a Backup-Frequenz in NavCenter, E.g. every 5 timesteps. Then star writes out a *.pst_<timestep> file, which is simply a *.pst file for that timestep.
Old   September 21, 2005, 11:11
Tom
I did this by accident myself once, wrote a transient file larger than 2 GB. I used the utility star convert under the tools>convert>star convert drop down menu. Under Post file type select transient and that allows you to specify the number of time steps for the new file. Under output file type select binary again and give it a new name with the pstt extension. Then hit apply. Just a typical warning, make sure you make a backup of the file before you start messing with it. If you end up needing to run it again you can run for fewer time steps (a size you can open) and then restart off that file for the next set of time steps.
Tom
Old   September 21, 2005, 20:31
limingtiger
thanks a lot.
Error Reading date file chnrdu OpenFOAM Running, Solving & CFD 13 January 29, 2013 02:35
Error reading trn file OliH CFX 3 March 4, 2010 08:24
Error when reading res file Taewon Seo CFX 1 April 28, 2009 09:09
Error reading msh file ANIL FLUENT 1 January 22, 2009 00:45
Error reading msh file into Fluent Ralf Schmidt FLUENT 5 October 30, 2005 20:00
