Making couples is too long!
Old   September 29, 2005, 09:59
Default Making couples is too long!
Vyatscheslav
Hi, Iīve got a lot of couples to make do in my mesh (arbitrary couples), and the command CPAR takes a long time to operate. How could I speed up the process?
: Playing with tolerances?
: Do it in several times?
: ...? Or maybe itīs the sign there will be errors...?(but I donīt think so)
Thank you V
Old   October 2, 2005, 04:51
Default Re: Making couples is too long!
Anton Lyaskin
Try to select only those cell, which will really participate in the matching process. CPAR looks for the couples in the current cell set.
Old   October 2, 2005, 23:03
som
first go for crack check. then cell plot. it will show only those cells where u need to do couple. then from couple tool do it or from cpmatch cset.
Old   October 5, 2005, 16:44
Paulh
Smalling up the cset is good advice. Also try using the 'Choose Attached Shell Types'. I've found that this helps create better couples.
Cell Couples in CCM+ norbinou Siemens 4 September 10, 2007 10:00
about couples bv Siemens 1 July 24, 2005 07:05
couples issue carno Siemens 1 April 16, 2004 02:58
Boundary Couples ale Siemens 0 January 26, 2004 05:09
couples or not couples... giosue Siemens 5 March 1, 2003 00:11
