Reading In Residual Dump Data in Star-CD v4.0
Old   May 31, 2006, 10:44
Default Reading In Residual Dump Data in Star-CD v4.0
SBottenheim
Hi, I am not sure how many people are using Star-CD v4.0 yet, but my question is as follows: how do you read a residual dump file?
Previous versions of Star-CD (ie: v3.x) allowed you to create a specific file with the extension .rpo
Apparently the .ccm file (which contains the .pst and .geom files) also replaces this .rpo file. However, when you load the .ccm file after a residual dump you cannot seemingly access the residual data - only the data that would be found in the .pst file
Does anyone know how to read this data?
Old   May 31, 2006, 11:28
Default Re: Reading In Residual Dump Data in Star-CD v4.0
SBottenheim
ok, so I solved the initial problem out: when accessing this data use the following command:
trload <filename.ccm>,,,residue
and then proceed as normal.
Now it appears however, that no residual data was dumped out. Any suggestions? Keep in mind this is for Star v4.0
Old   June 1, 2006, 16:45
Ronnie
I was told at the last user conference that before using star v4 you MUST contact your local account manager for advice and info if the features have been re-implemented in the code yet. The have the information already prepared.
R.
Old   June 2, 2006, 03:45
SBottenheim
Funny you mention that - I have been on the phone with Star-CD for the last couple of days. Essentially, the method I described here leads to a dead end when running steady-state (I am not sure if this is the way to get residual data when running transient). Essentially you need to input the following:
load <filename.ccm>,,Residue_<dump number>
Thereafter you will get all the residual data available. Anyway, just a pointer for anyone who is using Star-CD v4
reading data into fluent co2 FLUENT 0 December 28, 2003 01:31
CFX4: How to write user data to dump file? Min-Hua Wang CFX 3 July 17, 2003 20:49
Reading Data from a file Pravir FLUENT 3 February 16, 2003 04:57
Reading Conservative Variables from dump File Bilal Bukhari CFX 3 April 25, 2001 01:15
reading data from model yusoff CFX 3 March 19, 2001 23:12
