How to create a hole on the surface
Old   October 27, 2006, 17:36
Default How to create a hole on the surface
Radhika
Hi
I am relatively new to star cd. I have to model the flow in a circular duct with a hole on the surface. I need to use brick elements for meshing. How do I create the hole on the surface using star cd?
Old   October 29, 2006, 20:42
Default Re: How to create a hole on the surface
DB
You need to draw a solid model in either proE or SolidWorks and then export it in prosurf to triangulate the surface (create a surface mesh) and from there open it in proam to create a volume mesh.
DB
Old   October 29, 2006, 23:51
Radhika
Thanks a lot! I will try that.
Old   November 20, 2006, 06:06
kathir
using STAR-Design software you can draw the diagram very easily like modelling softwares. then you can create automatic mesh in star-design itself.
Old   December 8, 2006, 05:16
nkp
Dear,
you create a small cylinder (of hole dia) just above the surface on which u want to create hole.The length of cylinder take very small.Create shell on the surface of the pipe where you want to create hole.Then select the vertices of the bottom of the small cylinder.Project these vertices on the shell using vproj commmand. enjoy
How to create a circular surface? Jen FLUENT 7 December 7, 2020 13:09
Iso-surface: How do you create and display? Lukasz Mosakowski FLUENT 5 August 15, 2011 15:08
how to create surface mesh in icem5? Pete CFX 3 October 4, 2004 02:42
Create Thin Surface in Mesh2CAD Jeniffer CFX 0 November 4, 2003 17:24
create new surface subhash Siemens 2 July 30, 2002 03:53
