Axial Fan flow Meshing
Old   April 18, 2007, 09:53
Default Axial Fan flow Meshing
sidd
Hello Everybody,
Can somebody suggest me what kind of meshing is good for simulating Axial-Fans Flow, hex-dominant or tetra mesh with primatic layers. And which regions i need to keep mesh refinements, and how can i decide my cells size?
Thanks in Advance
Old   April 19, 2007, 18:22
Default Re: Axial Fan flow Meshing
thomas
Prefer Hex-mesh if possible for the rotating fan part! Refinemented mesh will be needed in the gaps between the rotor of the fan and the casing!
good luck, thomas
Old   April 19, 2007, 18:26
Pauli
Hex - tets are evil!
Old   April 20, 2007, 03:32
sidd
Thanks for the suggestions, i will try.
Axial Flow Turbine Problem Manish FLUENT 1 February 14, 2017 03:46
Axial flow turbine simulation dia CFX 1 November 20, 2008 11:03
simulation Axial flow turbine using CFX dia aisa CFX 3 May 2, 2008 02:45
Axial flow turbine approperiate B.C dia aisa CFX 0 April 30, 2008 03:32
axial flow gas-liq mixing Hari Saryono FLUENT 0 June 13, 2000 22:35
