Home > Forums > CD-adapco
problem in mesh generation-PROAM
Old   February 21, 2008, 04:27
Default problem in mesh generation-PROAM
Bala
Hi Tom and Pauli,
Thanks for your suggestions! I checked my surfaces and i did some corrections, infact i am getting the good subsurface than the earlier one. So i increased my sub surface to 500mm. But after generating the mesh with max edge length 350 and min edge length 10 mm. I am not getting the complete mesh. Its showing some unresolved cells and the mesh also not between the surface and the domain (doing external flow analysis). I think the problem is due to the error which i am getting as below. How to set the global tolerance.
Warning: 0.01 * minimum edge length is less than global
tolerance. The global tolerance is set to 0.0364453.
This setting may cause geometry detail in both
the surface and resulting model to be lost or
result in more unresolved cells.
Could you plz reply for this?
Bala
Thread Tools
Trackbacks are On
mesh generation problem Ellen FLUENT 7 February 18, 2009 21:20
PROAM: Problem in mesh generation Bala CD-adapco 0 March 5, 2008 05:53
mesh generation problem giyong CD-adapco 2 May 12, 2007 09:08
Problem with mesh generation Nestor FLUENT 3 November 1, 2006 02:54
Mesh generation problem Lam FLUENT 2 December 25, 2003 12:37
