March 9, 2008, 15:21 |
Interface in Star-CCM+
Hi guys,
I have two different regions in my computational domain, and I want to define an interface between the contact surfaces of these two regions - The perimeter of the surfaces are not equal. How would you define the interface?! |
March 11, 2008, 17:07 |
Re: Interface in Star-CCM+
You may have to redefine the geometry so that the perimeter of the surfaces match up. You can then generate separate meshes for each. For example, if you have a cover plate over a channel; where half is in contact with fluid and half is in contact with solid, make the cover plate 2 pieces and have specify two different interfaces.
March 12, 2008, 15:29 |
You look for the boundaries of each region which have contact with each other. Then mark the two and create interface in place. (right mouse click)
March 13, 2008, 08:48 |
try "zip edges" tools.. if they are so close.. create feature curves then zip the properly edges..
if only i can show you interactively good luck |
how to export a mesh from star design to star cd | aounallah | Siemens | 4 | March 6, 2009 06:22 |
the problem of running star-cd after pro-star | liu-jinsong | Siemens | 0 | November 20, 2008 20:58 |
