Moving Mesh Run problem - Scientific Linux
Old   May 6, 2008, 23:55
Default Moving Mesh Run problem - Scientific Linux
G. SE
I have worked for two month cause this problem.
When I solve tut7.3(moving asi), the slover is stop with next message.
/opt/StarCD/v3260/bin/star -fork PNP: Initialized [2008-05-07-12:05:10] Automatic Sequential Automatic Parallel analyzer.
PNP: Allocated "node001.cluster.com,1" resource (1 process).
PNP: Overload STAR master processor with external moving mesh code.
PNP: Assigned "node001.cluster.com,1" to STAR solver (1 process).
PNP: Assigned "node001.cluster.com,1" to external moving mesh code (1 process).
unrecognized option or trailing garbage
usage: ps -acehjlnrsSuvwx{t|#|O[-]u[-]U..} \
--sort:[-]key1,[-]key2,...
--help gives you this message
--version prints version information
PNP: Loading STAR solver dynamic shared object plug-ins.
PNP: Analyzing Moving mesh events.
PNP: Starting TRACKER task on "node001.cluster.com" for monitoring host and process failures.
PNP: Spawning STAR process on single node.
STAR 3.26.000 [Victoria_171]: linux64_2.4-pgf90_5.2-glibc_2.2.5-dso
RUNNING, CASENAME:
star
[1]: Dynamic Memory Allocated = 4 MB
*** Using FLEXlm licensing ***
License version 09-oct-2004
Checking license file: 1999@192.168.11.100
Checking license file: /opt/StarCD/v3260/license/license.dat
Unable to list features for license file /opt/StarCD/v3260/license/license.dat.
1 copies of starsuite checked out from 1999@192.168.11.100
Feature starsuite expires in 262 days
I set a Star-CD 3.26 at a Scientific Linux and license server is windows xp. These are connected hub.
This server runs succesfully other problem(parallel and two phase and so on) and crack version StarCD 3.26(windows)has no problem for runs moving mesh but moving mesh is failed always from Scientific Linux.
Please tell me how do I take this problem.
Old   May 7, 2008, 04:46
Default Re: Moving Mesh Run problem - Scientific Linux
Joern Beilke
If you do the mesh movement using prostar, 2 license features are checked out. If you have just one starsuite you can not run the case in this way.
It is possible when using newxyz.f for the mesh movement.
Old   May 7, 2008, 07:15
Anton Lyaskin
It should be possible to run with ProSTAR mesh movement if you quit ProSTAR before running the case and start it from console.
moving mesh problem eos Siemens 4 January 27, 2006 20:42
moving mesh problem walid Siemens 6 April 1, 2005 17:31
Erro while running moving mesh in linux version. xhliu1 Siemens 9 November 15, 2004 09:36
Can not using moving mesh in starCD of linux xhliu1 Siemens 4 October 17, 2004 09:12
Moving mesh problem Jan Majer Siemens 2 June 10, 2003 04:19
