Please Help Me
Old   January 14, 2009, 07:59
Default Please Help Me
Waseem Siddique
Hello I am modeling a smooth straight channel in Star CCM+. I want to find out the average Nusslt Number on different walls of the channel like side ad bottom walls. Also How can I find the total average Nusslt Number of the channel flow? Reply will be appriciated. Regards Waseem
Old   January 15, 2009, 01:19
Default Re: Please Help Me
usker
check out this http://www.adapco-online.com/adapco_...frontpage.html
Old   January 15, 2009, 10:07
Waseem Siddique
Its a fully loaded website with a lot of info..... can you please specify the related artical?? Thanks
Old   January 15, 2009, 19:33
ping
1. Create area averaged report(s) of heat transfer coef field function on the surface(s)
2. Create new field function(s) called Nusselt # and define is as per its formula using the field function(s) created by the above report(s), fluid conductivity and char. length
3. Create new 'max' report with N# as the field function and run this report.
Old   January 15, 2009, 21:18
usker
http://www.adapco-online.com/adapco_...frontpage.html ->Dr.Post->Calculating->Calculation of Nusselt Number
Old   January 16, 2009, 07:20
Waseem Siddique
Ping This was very helpful: In CCM+ there is a field fucntion of Nusttle number. Averaging it directly would give the same result, I assume. Waseem
