September 15, 2005, 11:12 |
Crack check problem
Hello everbody,
I´m working on a 3D airfoil. I`ve generated the mesh with ICEM then exported it to StarCD using CGNS format. During the crack check I´ m getting nearly 2500 cells with cracks within 48000 cells. I´ m using a crack limit smaller than my thinest cell edge. On the other hand when I observed these 2500 cells with eye, I couldn` t see any visual defects. What could be the reason for this problem? Tunc |
September 15, 2005, 12:41 |
Re: Crack check problem
Why didn`t you use the direct export form ICEM to STAR-CD?
September 16, 2005, 03:11 |
Actually, I´ ve done it also. But the number of the cells with cracks was the same.
September 16, 2005, 03:33 |
I can suppose, that these "crack" cells are the most thin in your model. If it is actually so, than the reason of your problem is too small relation of length cells to its height . But in practice, for my experience, it doesn't influence on solution field. You can save geom file and begin to calculate.
September 16, 2005, 03:38 |
You` re right Hadd. I` ve cracks within these cells. I` ll try it. Thank you...
September 16, 2005, 07:57 |
i think , if u have cracks in the model, it will not write the Geom File. check it.
BV |
September 20, 2005, 11:06 |
When you go to Check grid, then select check option Cracks, then try reducing delta. I've had this problem too.
March 16, 2011, 00:06 |
Rep Power: 15 |
hii after reducing delta even we save model and run, the delta value wont be the new value and it still indicates cracks.. what should i do?
Problem with 2D ICEM mesh check in fluent | Nicola | FLUENT | 3 | March 25, 2013 05:56 |
found crack in prostar but no crack in CCM+ ?? | Ingear | Siemens | 4 | October 23, 2006 09:37 |
Cell check and Boundary check errors | AB | Siemens | 4 | October 28, 2004 13:04 |
How do I check whether moving mesh problem can be | Harendra | Siemens | 0 | October 28, 2004 09:52 |
How to crack this problem | Lee | Siemens | 2 | September 12, 2003 10:40 |
