Ansys tutorial
Old   April 24, 2012, 07:32
Default Ansys tutorial
slim
slimmsk is on a distinguished road
I seek a TUTORIAL to simulate a cylindrical flow of a Newtonian fluid by ANSYS and ANSYS CFX FLEUNT.
I tried with ANSYS FLUENT but I can not get a flow with constant velocity. I always accelerating throughout the cylinder which have no logic.
I tried with ANSYS CFX but I did not understand (there are chemical reactions that I did not need) and I want some help.
My account is: http://www.cfd-online.com/Forums/members/slimmsk.html
My mail is: slimmsk@yahoo.fr
Thank you for all
slimmsk is offline   Reply With Quote
Old   April 25, 2012, 07:44
Your question raises more questions than it explains.
CFX and Fluent are both very capable CFD solvers. If they are doing weird things then you set them up wrong. Do more tutorials and training and things will be clearer.
You do not mention chemical reactions, so why are you saying CFX has chemical reactions you do not need.
Alternately if you want specific help on your simulation then post more detail and we will try to help.
Old   April 26, 2012, 16:41
slim
hello,
I try to simulate flow between two cylinders.
Normally I should get a constant velocity profile along the length.
But, I found an acceleration along the entire length of the cylinder.
Change speed / length axis> 0
normally it must be = 0
thank you
merci
Old   April 26, 2012, 18:37
This effect is probably real - compressible flows accelerate along a duct due to the fluid density decreasing, all flows (incompressible and incompressible) have the centre line velocity accelerate as the boundary layer develops and the centre velocity accelerates to maintain constant volume flow rate.
Old   April 27, 2012, 06:21
slim
In one study, I found this Fig 1 (that is what I should normally find).
But I find a profile as in Fig 2
I can not find the trick. Is that it's normal?
I despair
Thank you for the help
Old   April 27, 2012, 06:33
You have not described what you are doing so I cannot help you. As I already said, this effect can be due to the boundary layer forming cuasing the centre line velocity to accelerate, or it could be the acceleration of the flow due to fricition in compressible flow. As I have no idea what you are modelling I cannot be more specific.
Old   April 28, 2012, 04:48
slim
hello,
You find this link in a description for what I did.
This is another topic that I posted.
http://www.cfd-online.com/Forums/ans...ical-flow.html
If you have an article, a thesis or a study where I can find an explanation which I can pass it to me based retail?
thank you
Old   April 29, 2012, 07:00
Your flow is incompressible, so it appears the cause of the effect is development of the boundary layer causing acceleration of the core flow.
So this answers your question, doesn't it?
Old   April 29, 2012, 15:33
slim
hello,
yes, certainly for me, but I have to find a literature reference indicating the purpose in order to demonstrate the results that I present, and I can not find.
Thank you for your appreciable help and motivation for my question.
Old   April 29, 2012, 19:10
It is simple conservation of volume. No need for a reference, a few lines of maths proves it.
Old   May 1, 2012, 05:47
slim
hello,
if it is not too much, can you help me a little more.
thank you
Old   May 1, 2012, 19:18
Have a look at the flow at the inlet and the flow as it develops. See if you can work out why the centre line accelerates.
Old   May 6, 2012, 20:03
slim
hello,
how can I do to have a profile as in Figure 1. A constant speed over the entire length of the pipe.
The conditions requisent?
thank you
Old   May 6, 2012, 20:20
Just let the flow develop over a longer pipe.
Old   May 7, 2012, 12:20
slim
hello
I'm working on a configuration such that the length L = 300mm and diameter D = 25.8 mm.
I tried with a length L = 500mm, but I found the same result.
even in simulating with a flow of water.
I tried with ANSYS CFX and it is similar, and I even found a constant mass flow along the pipe.
thank you
Old   May 7, 2012, 17:14
Have you done a 1D pipe flow analysis to estimate how long the flow development is likely to be?
Old   May 8, 2012, 08:55
slim
No, I work with stationary regime, no time in the calculation.
it is important to wear the transient calculation with a time interval?
thank you
Old   May 8, 2012, 21:23
Flow development occurs both in space and time - the boundary layer needs to grow even for a steady state flow as the flow progresses along the pipe. So work out the pipe lenght required to get developed flow, and I bet you will find your model is a tiny fraction of that.
In other words I think your problem is that your domain needs to be much longer to let the flow develop to fully developed.
Old   May 10, 2012, 10:29
slim
hello,
I tried a simulation with ANSYS Fluent (I still have some difficulty with CFX):
Inlet velocity
Outlet pressure with mass flow rate
Time step size: 60 seconds
Number of time step: 5
Number of iterations / time step: 300
I find the same result
I noticed that the solver resolves five blocks of 300 iterations each time, is it recalculates every time?
60 seconds is enough or must I fix a few minutes
thank you very much
Old   May 10, 2012, 23:59
Use the Fluent forum for questions on Fluent.
These are pretty basic questions you are asking - surely you know how to determine if the flow is developing in time or not.
ansys, cfx, flow, fluent
Ansys tutorial slimmsk ANSYS 0 April 24, 2012 07:31
Tutorial ansys slimmsk FLOW-3D 0 April 24, 2012 07:30
Ansys Dynamics tutorial kajal ANSYS 0 May 21, 2011 01:14
Ansys 13.0 Explicit Dynamics Tutorial WenZyn Lim ANSYS 0 April 15, 2011 09:57
Questions about ANSYS ICEM CFD tutorial pquispea_m5 ANSYS Meshing & Geometry 3 December 5, 2010 15:58
