shock tube
Old   May 28, 2012, 01:58
Default shock tube
hamed
hamed.fg.mech is on a distinguished road
hi every one.......i modeled a shock tube problem in cfx v12.1 but its results have many fluctuation.......should i give 0 [atm] for refrence pressure?
problem:
air ideal gas.....high pressure:300kpa low pressure:150kpa
high pressure length:0.5m low pressure length:1.5m total time:0.001
RMS Courant Number:0.01 max Courant Number:0.04
do this value for max Courant Number is Logical?? do you can explain it?
thanks
hamed.fg.mech is offline   Reply With Quote
Old   May 28, 2012, 06:16
No. You should define the reference pressure as the base pressure in the model. Search the forum for further details, this question has been asked a lot.
Do a time step sensitivity check to establish the best time step size.
My PhD thesis has a discussion about things to consider when trying to get accurate shock wave modelling, see http://hdl.handle.net/2100/248
Old   May 28, 2012, 08:47
hamed
thanks a lot for replay....
do u can explain it for me....i solved my problem with a 0 atm refrence pressure and my results were logical when i use 1atm refrence pressure it didnt give a normal solve......what should i use for my problem as i say above
Do a time step sensitivity check to establish the best time step size?
how do i do it?
Old   May 28, 2012, 18:56
Both of these questions have been asked many times on the forum. Do a search to find them.
HLL Riemann Shock Tube Matlab Problem Luke F Main CFD Forum 2 May 20, 2016 02:10
Shock tube simulation harish FLUENT 5 January 25, 2014 02:20
rhoCentralFoam not reflecting shock in Shock Tube? Astaria OpenFOAM Running, Solving & CFD 5 March 4, 2012 03:07
shock tube validation AB Main CFD Forum 3 December 10, 2004 07:31
shock tube validation AB Siemens 0 November 21, 2004 18:43
