cfx diffusion to porous media
Old   November 9, 2012, 03:53
Default cfx diffusion to porous media
bitak
bitak is on a distinguished road
hello.
I want to simulate flow in tube that a porous media has been covered it ( exactly like blood arterial : blood + tissue).
how I can to simulate a normal diffusion from fluid flow to porous media in CFX ????
I described two domain and one interface.
bitak is offline   Reply With Quote
Old   November 9, 2012, 04:55
If the diffusion can be modelled by a diffusion or diffusion+convection equation then try an additional variable. You can put the AV in the fluid and let it diffuse through the surrounding solids.
Or do you want the fluid to diffuse through the solid?
Old   November 9, 2012, 15:08
bitak
Thanks for your answer. but I don't know what is different between define AV and diffuse fluid to suronding solid that you asked me
Old   November 9, 2012, 15:18
Have a look at the tutorials. A few of them use AVs. AVs can diffuse, convect or be defined as an algebraic equation. They do not have momentum like a fluid does. Temperature is a type of AV.
porous media combustion zuby FLUENT 2 August 31, 2015 04:42
How to define the porous inertial resistance and viscous resistance of porous media? pinfan143 STAR-CCM+ 5 July 21, 2015 11:52
laplacian foam simulating diffusion through a porous media mcdonalds OpenFOAM Running, Solving & CFD 1 February 1, 2015 16:51
Modelling sound propagation through layered porous media nkinar Main CFD Forum 0 July 4, 2010 14:45
Need help : porous media for heat exchanger X. Shen CFX 0 December 18, 2004 11:10
