How to get nodal values with a routine in preprocessor
Old   October 17, 2012, 04:09
Default How to get nodal values with a routine in preprocessor
l.te is on a distinguished road
Hello boys,
I'm doing a simulation when I must insert a thermal contact resistance between a cylindrical part and a die. The problem is that this thermal contact resistance depends on a "Distance function" that is f(Temperature, Additional variable "Alfa") with Alfa defined on the part domain.
I want the values of "Distance function" at every z over the length of the part.
To do that, I must do a routine (for cicle: How I can implement this in preprocessor?) in which I get the values of T and Alfa at every node along the "z" axis, but to do this, how I can access at the nodes of the mesh that I defined in mesher? And how I can say at the CFX Preprocessor: "you must get the T and Alfa values of every node at every z along the axis of the piece"?
Thanks
l.te is offline   Reply With Quote
Old   October 17, 2012, 05:56
Let's take a step back from details of the implementation. First, can you describe the function you want to implement? What is the distance function, and how is the temperature and alfa processed as inputs (ie, local value at the interface, averaged over a certain region, taken from another location, etc).
for cicle, get values, routine, take value, thermal contact resistanc
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
Extracting nodal values from a plane!! Thundil FLUENT 0 June 10, 2005 02:34
high difference between cell and nodal values Trilok FLUENT 2 November 13, 2003 03:38
nodal temperature values Mcgregor FLUENT 0 May 5, 2003 08:19
