Home > Forums > CFX
Identify connection between 3 Parts
Old   November 29, 2012, 06:12
Exclamation Identify connection between 3 Parts
Mahmoud Gabr
MGabr is on a distinguished road
Dear All
I am studding orifice behavior in high pressure systems and i have 3 parts the first is inlet pipe with flange and i Booleaned them in one part ( in DesignModeler ) , second part is the orifice and the third is the outlet pipe with flange so the sequence would be [ inlet pipe > flange > orifice > flange > outlet pipe ]
http://imageshack.us/photo/my-images/687/orifice.jpg/
i want to identify connection in Ansys mechanical between 1st flange , orifice & 2nd flange .
i identified them as contact connection between (orifice and 1st flange) and (orifice and 2st flange) and (1st flange and 2st flange) with contact type ( bonded )
when i run solver followed error appeared
| ERROR #002100061 has occurred in subroutine SERVE_CLIENTS. |
| Message: |
| The connection between this CFX process and an external process |
| has died unexpectedly. The following error was received: |
| External process : ANSYS |
| Error experienced : Read |
| ** This error is fatal: Terminating ANSYS CFX Solver execution ** |
| Please review the output, error and log files from both the CFX |
| and external processes to determine the cause of the error. |
Could anyone help in correcting my model for solving this problem
best regards
M.Gabr
MGabr is offline   Reply With Quote
Old   November 29, 2012, 11:08
Bruno
brunoc is on a distinguished road
Hi Mahmoud,
All this message says is that CFX lost its connection to ANSYS. This usually happens when ANSYS diverges. You should check your structural analysis model to see what could be causing this.
If possible, try running your structural model using a pressure level close to the one expected from CFX, or do a 1-way FSI analysis, and see if ANSYS is able to converge from that simulation. If it doesn't, the problem is in your structural model. If it does, the problem is most likely in the solver coupling parameters (assuming the CFX model is able to run on its own).
Cheers
brunoc is offline   Reply With Quote
Old   November 29, 2012, 11:51
Mahmoud Gabr
Hi Brunoc.
I had run this case before but as one part not 3 but i found that orifice material differ from pipe material so i had to divide them to 3 parts and use contact option.
now Solver solve the fluid domain loop or the outer loop but when try to start the external loop it failed.
Do you think that i used contact option correctly or i should other option for defining the bonding condition between ( flange-orifice-flange )
Thanks alot
M.Gabr
Old   November 29, 2012, 12:01
Bruno
If your model use to run and after you changed some parameters is doesn't, it's likely that something in your new model is causing the problem.
You should get each model running before you couple them; that means your structural model should be running without problem as a standalone model (without the FSI coupling - if the CFD pressure is an important part of the result, just import it into your structural model using WB). Get the correct settings for it and only than you should go back at coupling both codes.
Thread Tools
Trackbacks are On
Radiation interface hinca CFX 12 October 19, 2012 14:29
[ICEM] Generating mesh for modified parts in ICEM without changing mesh of other parts a.habibi ANSYS Meshing & Geometry 5 October 4, 2012 05:10
problem loading UDF library in parallel cluster Veera Gutti FLUENT 7 July 3, 2011 09:15
How to handle suction and pressure side of an airfoil as two different parts? TKE ANSYS Meshing & Geometry 0 March 4, 2011 07:48
One to one connection for periodic faces Al CFX 0 August 29, 2007 02:34
