HUGE change in results between opening and inlet
Old   October 30, 2013, 10:45
Default HUGE change in results between opening and inlet
Greg
gwheeler is on a distinguished road
I'm struggling to understand the difference between an opening and inlet boundary condition. I ran my model of a tube transporting hot gas and cooled by convection of the surrounding air domain. I tried changing one wall of the surrounding air domain from opening to inlet (in both cases I set the boundary temp and pressure the same). I get a really big difference in the resulting temperature drop of the hot gas. Can anyone explain why, and which boundary condition is more appropriate?
Thanks,
Greg
gwheeler is offline   Reply With Quote
Old   October 30, 2013, 11:23
keeper is on a distinguished road
even if it could be unreliable, have you tried static pressure on both cases as the BC?
keeper is offline   Reply With Quote
Old   October 30, 2013, 11:49
Greg
Yes, no significant difference in either case when I specify static pressure. Still a huge difference between the two cases.
Old   October 30, 2013, 12:22
you could try to extend both ends of BCs (inlet, outlet)
Old   October 30, 2013, 16:58
Have you looked at the velocity vectors? I bet the flow is totally different in the two cases.
simulation results don't match with experimental results funquest CFX 2 January 19, 2013 20:24
Using Opening B.C. for both inlet and outlet SH_P CFX 1 June 11, 2012 20:15
opening sims as a wall. Curran919 CFX 8 March 19, 2012 21:31
Difference in results using outlet and opening boundary conditions akash_max CFX 9 January 25, 2012 02:16
Inlet, Outlet, and ... Opening? PGP CFX 2 March 27, 2008 09:47
