Effective heat capacity - Phase change does not work!!!
Like Tree2Likes
  • 1 Post By papteo
  • 1 Post By step
Old   January 15, 2013, 09:29
Question Effective heat capacity - Phase change does not work!!!
Theodoros Papadopoulos
papteo is on a distinguished road
I am trying to simulate a PCM with the CFX. To simulate the phase change , i wrote an expression varying the heat capacity depending on its temperature in order to implement the effective heat capacity for the melting phase. The normal value of the specific heat capacity is 1200 J/(kg K) and during the melting area 100.000 (J/kg K). My problem is that I do not obeserve any change at the temperature during the phase change while the Cp has the right value according to my simulation! The temperature should have remained constant for a certain time or at least the temperature increase should have been smoother
I am attaching also two photos from the post-processing which show the Cp and Temperature over time!
Can anyone help me with this problem?
step likes this.
papteo is offline   Reply With Quote
Old   January 15, 2013, 11:00
step is on a distinguished road
Hi there,
I would also be interested in a solution. I've found some bits of literature that suggest an approach using an effective heat capacity to account for the energy necessary for a phase change.
Any ideas?
papteo likes this.
step is offline   Reply With Quote
Old   January 15, 2013, 20:57
What are you actually modelling? How are you driving the temperature?
Old   January 16, 2013, 03:49
Hi Glenn,
thank you very much for your interest. What I am actually doing is to test the principle of the effective heat capacity for a phase change material. I am modelling a cube (PCM-solid) which has an initial temperature of 45 °C and one side is heated up with 10.000 W/m² . The PCM has a very high Cp value within the melting field (e.g. 50-60 °C). As mentioned above my goal is to monitor a constant temperature within this temperature field. Instead the temperature is rising without observing any change at the temperature contrary to the Cp value as the pictures show.
Do you have any ideas why this is happening?
Thank you very much in advance
Old   January 16, 2013, 16:45
Obviously your variable CP is not beign applied. Check that it is the CEL properly. Also check that the table CFX uses to model variable properties is appropriate to capture the non-linear bits of your Cp curve. You might need to tighten the table temperature limits, or put more points in the table.
Old   January 17, 2013, 09:20
Thank you very much Glenn for your advice. I just increased the number of the points and the problem was solved.
Once again thank you for your help and quick answer!
Old   October 23, 2013, 21:16
John
jjdd2011 is on a distinguished road
Thank you for your help. Just wonder where is the table CFX used to model variable properties.
jjdd2011 is offline   Reply With Quote
Old   October 24, 2013, 05:27
It is internally generated. You define how many points the table has, but do not access the table directly. You can see its result by looking at the material properties it ends up with in the post processor if you like.
Old   October 31, 2013, 05:15
John
Thanks a lot. After I have posted the question, I realized that it can be in material property setting. I changed the number of points. It worked. Great help.
error message cuteapathy CFX 14 March 20, 2012 06:45
Flash Process / Problem with thermal phase change model Ridley CFX 0 July 21, 2010 07:57
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 15:45
VISCOUS heat dissipation Joseph CFX 0 October 1, 2004 08:52
