September 9, 2013, 00:31 |
Heat pipe
Saleh
recently, I got project to do simulation for it this project was using heat pipe as heat transfer tecniqe to enhace heat transfer between the heat transfer fluid and phase change materials. my question is how 2 set the heat pipe with CFX |
September 9, 2013, 01:03 |
Rep Power: 143 |
Heat pipes are difficult to simulate due to the multiphase flow and condensation and vapourisation. This is not a flow for beginners and you are not going to find a tutorial on setting them up.
September 9, 2013, 01:23 |
Heat Pipe
Saleh
I englect the advective effect of liquid return from the condenser to the evaporator. In addition, the resistances due to evaporation and condensation inside the heat pipes are assumed to be negligible
September 9, 2013, 01:36 |
Heat Pipe
Saleh
Dear, All
Please if any body have any knowledge please help with kind regards Saleh |
September 9, 2013, 01:55 |
Rep Power: 143 |
Can you post an image of what you are proposing to model, and the important physics.
September 9, 2013, 03:37 |
Heat Pipe
Saleh
Thanks ghorrocks for your reply
I attached my geometry with this message. I'm using Therminol VP-1 as heat transfer fluid, Potassium nitrate as phase change material, steel for tube and heat pipe. The dimensions for heat pipes (Condenser length 0.140m, Evapporator length 0.100m, and Adiabatic length 0.060m). The tube dimensions (Tube outer radius 0.250m, Tube wall thickness 0.003m). The module length 0.120m. I'm following published paper for all these information |
September 9, 2013, 05:42 |
Rep Power: 143 |
I have no idea what that image shows. Can you please explain what it is showing.
What are you trying learn with this simulation? |
September 9, 2013, 06:59 |
Heat Pipe
Saleh
Dear, ghorrocks
If possible please post your e-mail and I will send to you a paper I'm following and we will make deeply discussion about my case. Regards Saleh |
September 9, 2013, 07:31 |
Rep Power: 143 |
I do not give my email on the forum. And don't PM me either, I do not answer CFD questions by PM.
Post it on the forum. |
how to analysis double pipe heat exchanger in cfx | rammax8 | CFX | 12 | February 14, 2014 16:10 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
FEA Simulation of heat pipe | bensonnggl | ANSYS | 0 | September 25, 2010 00:59 |
heat transfer through fluids in a pipe in pipe | madasu | FLUENT | 1 | July 15, 2002 10:14 |
