phase change problem
Old   November 20, 2013, 22:23
Default phase change problem
cscfx is on a distinguished road
I want to simulate a subcooled boiling problem. the physical condition as follows:
circular tube : length 2m,diameter:0.0154m,pressure:4.5MPa,uniform wall heat flux :570000. inlet velocity :1m/s. After set up all the parameters ,there some mistakes: "While evaluating Fluid 1.Local Speed of Sound, |
Absolute Pressure went outside of its upper limit. Its maximum value was 4.5134E+06. The bounds error was handled by clipping. |
If this situation persists, consider increasing the table range"
WHO knows how to deal with this problem? thank you a lot!!!
cscfx is offline   Reply With Quote
Old   November 21, 2013, 04:09
Firstly, check what is the correct pressure range for this simulation. What is the maximum pressure anywhere? Then set the upper pressure limit for the speed of sound in the material property to this value * 150% to give you some clearance.
If you still get it then your simulation is not numerically stable. This is similar to the overflow error issue and there is an FAQ on that: http://www.cfd-online.com/Wiki/Ansys...do_about_it.3F
simulation of phase change material melting rosol FLUENT 4 December 8, 2015 07:56
Solid/liquid phase change using large viscosity gregor.vidmar153 OpenFOAM Running, Solving & CFD 3 June 10, 2010 06:31
Two phase flow with phase change Ahmad Al-Zoubi CFX 1 November 26, 2008 03:59
How to model the solid-fluid phase change in CFX ohrmond CFX 2 May 26, 2006 06:27
Phase change process Sang-jin Lee Siemens 5 December 5, 2001 05:17
