Water diffusion into air
Old   March 16, 2014, 01:57
Question Water diffusion into air
Mahmoud Gabr
MGabr is on a distinguished road
Dear experts;
I have a problem in modelling my first multiphase model. simply, it is a static water in a closed volume with air (volume fraction is 0.3 for liquid water and 0.7 for air), All volume walls have 80 C0 temperature. volume is closed so no inlet or outlet.
The required is the volume fraction of water vapor due to diffusion (there is no boiling in this problem) in the steady state case and then it would be converted to transient case for calculating diffusion rate.
I have tried to model it by define fluid phases as follow; Air , water and water vapor. I had selected homogeneous multiphase model with homogeneous heat transfer model. turbulence model is K-Epsilon and fluid pair model was defined for Air and liquid water phase for the interphase transfer is free surface. Also defined for air and water vapor as mixture. initialization condition for the volume fraction for each fluid was defined (air =0.3 water liquid =0.7 and water vapor =0)
I had searched in ANSYS help for diffusion schemes in expert parameters but i didn't find enough data explaining each scheme so until now I didn't use any scheme in solving.
Could someone suggest ideas for improving this model and give me links explaining diffusion schemes better as until now I have this like for explaining this schemes but it is also not enough [http://www.arc.vt.edu/ansys_help/cfx...SolvDisc.html].
Thanks
MGabr is offline   Reply With Quote
Old   March 16, 2014, 04:42
You will have to describe what you are doing more thoroughly for us to help.
Is there a single air/water interface? Is the bottom 30% of the box filled with water and the top 70% filled with air? Does it have a distinct interface between the air and the water? Are there water droplets or air bubbles? Is the humidity of the air important? Is water evaporation important?
Old   March 16, 2014, 06:02
Mahmoud Gabr
Thanks ghorrocks
following is answer for your questions
Is there a single air/water interface? yes, water upper surface.
Is the bottom 30% of the box filled with water and the top 70% filled with air? yes
Does it have a distinct interface between the air and the water? condition for a simple interface between water and air.
Is the humidity of the air important? Is water evaporation important? both yes, because I want to develop this model for determine the effectiveness of water desalination system in evaporating water and also water diffusion due to concentration into air.
please let me know if there are more questions for clarifying my model.
Regards
Old   March 16, 2014, 17:06
So it appears you have a multiphase model (liquid water versus air), and the air is a multicomponent gas (air+water vapour). The water vapour in air is not a multiphase model as the water vapour is the same phase as the air.
The liquid water/air multiphase bit should be straight forward. A multicomponent gas is also straight forward. The tricky bit in this simulation is to get the conditions right on the interface so water evaporates (and condenses if necessary) at the correct rate and adds to the water vapour.
But before you work on the evaporation on the interface do a multiphase model (water/air) and a multicomponent model (water vapour/air) first with no evaporation at the interface to make sure the basic stuff is working first.
Old   March 16, 2014, 23:30
Mahmoud Gabr
So how can model this ghorrocks,
1- should I build 2 volumes one for water and another for air and make an interface between them?
2- if Yes ;How can I define fluid in a volume (domain) , and define another fluid in another domain because when I divided the total volume into 2 volume, I couldn't define one or more fluid for each one differ from the other volume.
3- what would be the interface type between the 2 volumes (assuming the first question answer is Yes) for modelling the evaporation and diffusion on water free surface.
Regards
Old   March 17, 2014, 03:41
Is the interface location fixed? Do you care about the flows in the water and the air?
Old   March 17, 2014, 05:19
Mahmoud Gabr
-when I had defined the interface, it was fixed related to named selected face . can I make it variable or imaginary, as the free surface of the water volume would not fixed while water vapor is evaporating from the water liquid into air.
-Yes I care about both flow in the water and the air
Regards
Old   March 17, 2014, 16:25
It is still not completely clear but I suspect a free surface multiphase model for the air/water interface will work, and multicomponent mixture for the air/water vapour.
So have a look at the CFX tutorials for setting up free surface simulations. It also has examples on multipcomponent mixtures. But combining them together you will have to work out yourself.
Old   March 17, 2014, 16:47
Mahmoud Gabr
Okay, but could you tell me how to define one or more fluid for a domain and another one fluid or more for another domain. I have tried many times for doing that and unfortunately couldn't also I have tried to find a tutorial for that and also couldn't.
Old   March 17, 2014, 16:48
Your simulation is a single domain. Have a look at the flow over a bump tutorial for how to set up free surface multiphase simulations.
Old   March 18, 2014, 16:17
Mahmoud Gabr
Thanks ghorrocks; I am looking at it right now
Regards
Old   April 14, 2014, 03:55
Mahmoud Gabr
Hi ghorrocks;
I have tried many tutorials and finally I can model 2 phase flow . Now I have a new problem in defining condensation of water vapor on low temperature vertical wall. could you help me in defining it correctly or give me a tutorial for this case. my case is closed volume (2D) , VOF , transient , water vapor at 400K and cold wall at 280K. no inlet or outlet just closed volume.
Best regards
Old   April 14, 2014, 07:22
I do nto have any tutorials for the wall condensation model. Try the ANSYS community page as it might have one. Otherwise ANSYS support will have some I suspect, so get in contact with them.
Old   April 14, 2014, 14:39
Mahmoud Gabr
Thanks ghorrocks for your guidance. I will try both of them. thank you
Old   November 19, 2020, 23:12
Default Mr
  #15
jiangsu
Romu is on a distinguished road
Originally Posted by MGabr View Post
Hi ghorrocks;
Best regards
@ghorrocks and@ MGabr, Can you please guide one how i can simulate two phase flow, i mean air which is compressing water in pressure vessel. there is no mixing between them. simple, i have inlet of water at down and inlet of air at the top of pressure vessel. thanks
Romu is offline   Reply With Quote
Old   November 19, 2020, 23:40
CFX has many tutorial examples available which show how multiphase modelling is done. You can get them on the ANSYS Customer website, or the ANSYS Academic website depending on whether you are a commercial or academic customer.
There are also lots of CFX tutorials available on youtube and other sources on the web. They are not hard to find.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   November 20, 2020, 01:35
jiangsu
Originally Posted by ghorrocks View Post
CFX has many tutorial examples available that show how multiphase modeling is done. You can get them on the ANSYS Customer website or the ANSYS Academic website, depending on whether you are a commercial or academic customer.
Thank you very much for the quick reply to my message.
Yeah, I have visited and watched many tutorials on two-phase flow, but I haven't found exactly the flow explaining the air that is compressing water in pressure vessel. If you know exactly, kindly share the link with me. Thank you once again.
Old   September 3, 2023, 18:45
Gokhan Pulati
asabiMech is on a distinguished road
Hi ghorrocks, I am experiencing the same difficulty with the OP, the only difference is that I am using Fluent. I think the procedure is a bit different on the Fluent side for a free surface evaporation, I posted in the forum but couldn't get any answers. Can you also help guiding me the same case in Fluent?
asabiMech is offline   Reply With Quote
Old   September 3, 2023, 19:04
Questions about Fluent should be asked on the Fluent forum. If you are not getting any response there then have a think about why nobody is interested in responding and try again.
The way you apply these models is very different in CFX versus Fluent, so I will not be able to help you much.
Old   September 3, 2023, 19:06
Gokhan Pulati
You are right, I should have been aware that there are different forums. Thank you anyway!
diffusion-type, multiphase flow
I am NOT getting right pressure at the air inlet in water column kcfd FLUENT 0 November 24, 2012 23:14
Boiling of water with hot air Dr. Flow Squad CFX 2 July 27, 2009 07:37
Mass diffusion of surface exposed to water flow Derek FLUENT 3 February 27, 2006 14:38
VOF-compression of air with rising water yavuz FLUENT 0 November 26, 2005 09:00
