April 22, 2014, 21:59 |
mesh displacement in CFX
Ma.L
Rep Power: 13 |
I want to know the displacement of a particle in one certain direction,for example direction Y,so i use the motion mesh.But there are two kinds of displacement:Total Mesh Displacement Y and Mesh Displacement Y.If i want to know the motion trail of a particle in direction Y,which one i should refer to?Namely,what is the difference between the two kinds of displacement?
Thanks! |
April 22, 2014, 23:12 |
Rep Power: 143 |
I suspect you are getting confused between all the different displacements.
"Mesh Displacement" and "Total Mesh Displacement" refer to the motion of the MESH during a moving mesh simulation. It has nothing to do with the fluid flow or the motion of particles. The variable "velocity" is the velocity of the FLUID. Neither of these variables tell you anything about the motion of a particle. If you are using lagrangian particle tracking then I think it is "Particle velocity". If you are using eularian particle models then you will have to do some work to extract the particle motions - maybe a streamline of the particle phase velocity field. If you are doing a rigid body simulation then it is in the rigid body variables. |
April 27, 2014, 03:21 |
#3 | |
Ma.L
Rep Power: 13 |
Thanks for you reply. I am using motion mesh for processing the simulation of the vortex-induced vibration for a cylinder.Now,i want to know the displacement of cylinder during the VIV, so i create a monitor particle on the center of cylinder,then i monitor this point I create when CFX is on solving.The question is that I have monitor the "Mesh Displacement" and "Total Mesh Displacement" for the user point, however i don't know which one is the real displacement of the point.Namely,what's the difference of the "Mesh Displacement" and "Total Mesh Displacement". At last,I attached three graphic for this problem. Kind regardsviv.JPG mesh disp Y.jpg total mesh disp Y.jpg |
April 27, 2014, 06:37 |
Rep Power: 143 |
It depends on how you have set it up, but Mesh displacement will probably be the change in mesh position from the last time step, and total mesh displacement is the absolute position of the mesh. The total mesh displacement is the integral of the mesh position.
May 21, 2016, 04:24 |
Viv cylinder
abubakar izhar
Rep Power: 10 |
Dear
I am trying to simulate VIV of CYLINDER IN CFX rigid body solver. I have made a sub domain around cylinder which follows the rigid body motion. Which type of mesh motion should I set on both sides of fluid fluid INTERFACE between the sub domain and outer fluid domain. If I use rigid body motion on both sides then mismatch between the mesh occurs on both sides of INTERFACE. SHOULD I USE conservative INTERFACE FLUX on both sides. What are effects of both. Moreover when I use conservative INTERFACE FLUX on both sides I get negative volume mesh but when I use rigid body solution on both sides I don't get negative volumes . The stiffness is set to 1[m5 /s]*VOLUME OF FINITE VOLUMES. Please guide. |
May 21, 2016, 06:19 |
Rep Power: 143 |
The FAQ on this issue (http://www.cfd-online.com/Wiki/Ansys..._went_wrong.3F) has a tip on visualising the mesh motion. This is highly recommended for debugging mesh motion simulations.
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface | Kryo | OpenFOAM Meshing & Mesh Conversion | 13 | February 17, 2022 07:34 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
Periodic displacement // Moving Mesh | Badi | CFX | 0 | April 10, 2013 07:50 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 09:03 |
[ANSYS Meshing] Question about ICEM mesh output to CFX | lnk | ANSYS Meshing & Geometry | 0 | July 27, 2012 15:39 |
