September 27, 2013, 15:01 |
Fatal overflow in linear solver
ali
Rep Power: 17 |
I am simulating air flow around a turbine blade. I can obtain the solution when turbulence model is set to K-epsilon and K-Omega. When I want to run the case with SST, I receive the following error message. The solver crashes in the very first iteration. The simulation is steady state. I have reduced the timescale factor to 1e-6 and moved the boundaries away from the blade and also increased the memory allocation factor. p, li { white-space: pre-wrap; } +--------------------------------------------------------------------+ | ERROR #004100018 has occurred in subroutine FINMES. | | Message: | | Fatal overflow in linear solver. | +--------------------------------------------------------------------+ Any suggestions? Thanks |
Fatal overflow in linear solver error. Why? | zaidun | CFX | 7 | August 11, 2016 05:59 |
time consuming of the linear solver | luckycfd | OpenFOAM Programming & Development | 3 | September 23, 2013 05:29 |
Use "bounded" in scheme or not to use? | immortality | OpenFOAM Pre-Processing | 0 | June 11, 2013 16:20 |
solution diverges when linear upwind interpolation scheme is used | subash | OpenFOAM | 0 | May 29, 2010 01:23 |
