April 26, 2016, 13:00 |
CFX Pre
Ibadullah
Rep Power: 10 |
Dear All,
I want to ask from anyone that when I decreased the time step size then the convergence becomes slow but if the RMS residuals does not change from 13 iterations then does it mean convergence have achieved or not or I have to wait for the specified convergence. Answers will be appreciable Thanks Regard Ibad |
April 27, 2016, 03:03 |
Rep Power: 12 |
what is your case? turbomachinery, nozzle, air foil, ... ? it depends on the case, for example in compressor or turbine, constant efficiency and imbalance too close to zero are good criteria for convergence. but for air foil constant LC and DC are important. |
April 27, 2016, 15:22 |
Ibadullah
Rep Power: 10 |
Thanks for reply. Actually its a venturi scrubber that consist of a converging, throat and a diverging section where air enters from converging section and the water enter from nozzle into throat area. I have attached the pic So what did you say about it now . Thanks
Regard Ibadullah Safdar |
April 28, 2016, 02:44 |
Maxim
Rep Power: 12 |
Hi, your thread title is bad. Your question has nothing to do with CFX Pre. Please be more specific.
Read what I just wrote here about residuals and try that out too: http://www.cfd-online.com/Forums/cfx...tml#post597054 Also as Ali wrote, have a look at the imbalances. I would say that no changes in 13 iterations are not enough to tell if convergence is achieved. How do your monitor points look like besides the residuals? |
April 28, 2016, 11:53 |
Ibadullah
Rep Power: 10 |
Thanks maxim for ur reply. i will try what you have said in your previous post.
Regards Ibadullah safdar |
Only two turbulence options available in CFX Pre | Jack001 | CFX | 5 | March 30, 2016 02:47 |
air ideal gas in CFX Pre | wangy1767 | CFX | 9 | October 1, 2012 07:55 |
CFX Pre Domains for centrifugal pump | MechKim | CFX | 1 | September 24, 2012 08:06 |
CFX Pre Hide symmetry symbols | alvid | CFX | 2 | August 15, 2007 11:34 |
CFX 10 -pre and -post problams on Linux | Henry Liu | CFX | 3 | June 22, 2006 06:57 |
