High %SD-Sur Values @ I-Radiation Full Spectrum
Old   June 24, 2016, 10:05
Default High %SD-Sur Values @ I-Radiation Full Spectrum
volleyHC is on a distinguished road
Hey Folks,
I am doing a simulation of an solar-absorber, which seems to calculate very well. But I have problems with very high %SD-Sur values in th I-Radiation Full Spectrum (as u can see in the pictures), and I don't really have a clue how to fix it. The values fluctuate from 59% up to 100%.
My Model is very simple. Just a pipe with solar radiation from the outside.
So I hope somebody of you have any hints to lower that %SD-Sur values.
thanks an best regards
volleyHC
volleyHC is offline   Reply With Quote
Old   June 24, 2016, 10:31
Opaque will become famous soon enough
One question, how many histories are you using ? How much does the SD% changes, if you increase the number of histories by a factor of say 10?
Also, you can plot the Wall Irradiation Heat Flux.Normalized Std Deviation on the boundaries of your domain. On such plot, you may find the areas where the standard deviation is high, and decide if the sampling in that region is critical for your simulation.
Opaque is offline   Reply With Quote
Old   June 24, 2016, 11:22
I am doing 2,500,000 Histories at the moment. I did 1,000,000 before, but it didnt chang very much. I could try 10,000,000 but that would increase my calculation time too much I guess - but mabye it's the only way.
I looked up the Heat Flux.Normalized Std Deviation . And it looks like this:
Well, I just refined my mesh very much, start my calculation again and got this message:
 |                     ****** Notice ******                           |
 |  Spectral band contribution to the spectrum is negligible          |
 |  Domain       : Default Domain                                     |
 |  Spectral Band: Vis                                                |
 |  Contribution :  0.60135-153                                       |
 |  Spectral Band: UV                                                 |
 |  Spectral Band: NIR                                                |
Is that anything to worry about, or just an information?
Old   July 24, 2016, 13:03
Does anyone has some hints/clues for me, to fix that problem?
Old   August 9, 2016, 14:08
Lukas
Birnensuppe is on a distinguished road
Hey volleyHC,
have you figured out a solution for this problem?
Kind regards
Birnensuppe is offline   Reply With Quote
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 09:49
High Values of Cl,Cd,Cm taimoor FLUENT 1 February 4, 2009 02:00
RMS values too high! Usman Main CFD Forum 12 February 7, 2008 11:43
RMS values too high! Usman CFX 1 January 22, 2008 16:53
