August 8, 2016, 03:24 |
How important is prism layer in fluid flow?
Rokson K Mathew
Rep Power: 10 |
I have been doing fluid analysis on pumps and turbines. I have always used prism layer giving y+ <2. What would the variations in the total result be if I do not add prisms and use only tetra mesh. Other than the flow through the boundary layer, what could be the total variation in other parameters say total pressure and torque be? Regards Rokson |
August 8, 2016, 06:03 |
Rep Power: 143 |
That is dependant on what you are modelling. It could make the results completely wrong by a massive amount, or it could have no effect. It all depends.
The best thing to do is to just try it on your case and find out for yourself. |
August 8, 2016, 12:00 |
Rep Power: 32 |
You mesh count will increase drastically because of the poor resolution a high aspect ratio tetrahedral mesh provides.
Recall that flow in a boundary layer has very sharp/high gradients normal to the boundary; therefore, you need very thin tetrahedral elements normal to the boundary and to satisfy a non-drastic aspect ratio changes along the boundary, you will need A LOT more elements than hexahedral, or prismatic elements. Hope the above helps, |
August 8, 2016, 20:14 |
Rep Power: 143 |
Hi Opaque,
Your comments are correct for mid to high Reynolds number flows where wall friction is important. But in very low Re flows a tet mesh to the wall is fine (eg MEMS flows), or in inviscid flows it does not matter either. While it is true most simulations are mid to high Reynolds numbers where inflation layers are important it is not the case for all simulations - hence my vague answer. |
prism layers, pump boundary condition, pump mesh, turbine mesh |
Prismatic boundary layer | KateEisenhower | enGrid | 5 | September 15, 2015 07:48 |
Waterwheel shaped turbine inside a pipe simulation problem | mshahed91 | CFX | 3 | January 10, 2015 11:19 |
Help: Fluid Flow Over a Horizontal Flat Plate by Boundary Layer Eq. | egemen | Main CFD Forum | 0 | May 20, 2011 04:57 |
Prism layer advice needed for port flow case | MaxCFM | ANSYS Meshing & Geometry | 0 | October 2, 2009 08:42 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
