can not continue running simulation with trn file
Like Tree2Likes
  • 1 Post By Lance
  • 1 Post By Opaque
Old   September 14, 2016, 12:14
Post can not continue running simulation with trn file
mao
mao
mao is on a distinguished road
hello,i am now running one simulation in cluster, i stooped in the middle and have a file.trn(finished 2000steps), i wanna start with this file to finish another 1500steps, however, the new simulation starts from beggining(0step) instead of the file.trn(2000steps), hope someone can give some suggestions, thank you very much.
mao is offline   Reply With Quote
Old   September 14, 2016, 16:26
Opaque will become famous soon enough
Can you describe how you are restarting the simulation ? Either from the command line (cfx5solve), or the steps you are following in the ANSYS CFX Solver Manager
Opaque is offline   Reply With Quote
Old   September 15, 2016, 04:32
mao
mao
hi,opaque, thanks for your kind reply.following are some details about my simulation.
1,i have an unsteady simulation,totaltime=8s,
2.first stage. i have to stop at t=2s due to some reasons, then we have some trn files(let us call the last trn file as 2.trn).
3.second stage, i should regard 2.trn as initial file in the second simulation, and then keep going the next 6 seconds.
4.in the first simulation,totaltime=2s, whereas it equals 8s in the second simulation,
5,in normal computer or severs, i can choose "continue history from" in solver define run. but now i have to use cluster where i give a command file whiched showed in 6, either i start from bak file or trn file, the second simulation starts from 0 second rather than 2 second.
6.
#!/bin/bash -l
#PBS -N XiuliSimulation
#PBS -l nodes=2pn=16:NRM
#PBS -l walltime=999:00:00
SIMNAME=casoCFX
export SIMNAME
ANSYSLMD_LICENSE_FILE=1055@147.162.153.181
export ANSYSLMD_LICENSE_FILE
ANSYSLI_SERVERS=2325@147.162.153.181
export ANSYSLI_SERVERS
cd $PBS_O_WORKDIR
#mkdir /usr/data/$SIMNAME/
#cp -R * /usr/data/$SIMNAME/
#cd /usr/data/$SIMNAME/
nodes=`cat $PBS_NODEFILE`
nodes=`echo $nodes | sed -e 's/ /,/g'`
# con initial file
/opt/ansys/v161/CFX/bin/cfx5solve -double -initial-file /home/wissam/xiuli/foldername/filename.trn -def /home/wissam/xiuli/foldername/filename.def -par-dist $nodes -sizepar 1.1 -size 1.1
# senza initial file
# /opt/ansys/v161/CFX/bin/cfx5solve -def /home/wissam/christian/td600_unsteady/td600_unsteady.def -par-dist $nodes -sizepar 1.1 -size 1.1
#mv /usr/data/$SIMNAME/* $PBS_O_WORKDIR
#rm /usr/data/$SIMNAME/* -r
Old   September 15, 2016, 04:48
Lance
Lance is on a distinguished road
your batch script was not very clear, but make sure you understand the difference between -initial-file and -continue-from-file
the first will make the simulation start from zero with initial values from the specified file, the second will continue the simulation using the initial values file.
mao likes this.
Lance is offline   Reply With Quote
Old   September 15, 2016, 10:50
To complement Lance's response, you must also understand the differences between n.trn and n_full.trn files.
n_full.trn files are effectively final results file for a given timestep (n), and you can safely restart from them.
n.trn files are considered minimal transient files, and only contain data to be visualized by a successfully finished run. That is, on their own they do not have enough information to be used.
Hope the above helps,
mao likes this.
Old   September 23, 2016, 10:31
mao
mao
thank you,guys, your information are very useful to me, thanks again sincerely.
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 03:30
[Other] How to use finite area method in official OpenFOAM 2.2.0? Detian Liu OpenFOAM Meshing & Mesh Conversion 4 November 3, 2015 03:04
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 01:41
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
ParaView Compilation jakaranda OpenFOAM Installation 3 October 27, 2008 11:46
