Small water turbine with TASCflow
Old   September 25, 2000, 05:52
Default Small water turbine with TASCflow
Drona
Dear All,
I am trying to analyse performance of a small hydraulic reaction turbine(propeller) using CFX-TASCflow. I would like to compare its performance(efficiency) at different operating conditions. What is the simplest parameter that can be used? I tried to calculate efficiency using the Macro Turbo_Perform but I am not getting consistent results. Sometimes I get zero torque etc. However, the solution looks fine. For example, there is a pressure difference between inlet and outlet(positive at inlet and negative at outlet), that should give some torque. Any clues will be appreciated.
Thanks
Drona
Old   September 25, 2000, 09:59
Default Re: Small water turbine with TASCflow
John C. Chien
(1). Have you tried to contact the support engineers of Tascflow? (2). If you compute the inlet and the exit flow tangential momentum change in stationary reference frame, it should be able to give you information about the torque. (look up the formula in the turbomachinery chapter,or books first)
Old   November 29, 2000, 13:53
sarvankumar
we have donean analysis in water pump which is similar to a turbine, if you are interested i can suggest you the method which i followed thanks with regards p.t.saravanakumar
How simulate air bubbles into water turbine? farzola Main CFD Forum 0 April 8, 2010 09:35
Water turbine - TSR/power Zaqie FLUENT 0 March 29, 2010 14:01
Power in water turbine Zaqie FLUENT 2 March 2, 2010 17:05
Separation phenomenon of water, droplet and air Raymond CFX 0 July 9, 2004 22:59
CFD package for small propeller turbine design Drona Upadhyay Main CFD Forum 13 November 16, 1999 23:20
