February 18, 2002, 10:30 |
Boundary conditions
Hi
I was wondering if anyone knows how you apply more than one boundary condition such as velocity to one surface. Another question, if I draw a geometry with the full 360 degrees but only want to simulate over 90 degrees, do I redraw only 90 degrees or is a way of specifying over what portion you want to carry out a simulation. Jennifer |
February 19, 2002, 02:03 |
Re: Boundary conditions
If your using CFX-5 then you could create a CEL expression for velocity which varies across the boundary surface.
As for the second question, if you've done this in CFX-5 then you need to recreate the geometry and remesh. You should be able to just reopen the old database and all you settings will be remembered. If you had thought you might want to do this ahead of time then you could have created your geometry as four 90 degree subvolumes, then you would only need to delete 3 of the volumes and redefine the fluid domain. Neale. |
February 23, 2002, 23:41 |
Hi Jennifer,
1) What do you mean by more than one boundary condition? 2) Break your original model into multiple solids. When you select the bounding solids in the domains form, select only the segment you want to model. If you need the remaining segments later, you can simply modify you domains again. Robin |
Impinging Jet Boundary Conditions | Anindya | Main CFD Forum | 25 | February 27, 2016 12:58 |
symmetry boundary conditions in cfx | lost.identity | CFX | 41 | May 22, 2013 07:21 |
OpenFOAM Variable Velocity Boundary Conditions | NickolasPl | OpenFOAM Programming & Development | 2 | May 19, 2011 05:37 |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 09:38 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
