A rotating solid domain in CFX551?
Old   January 4, 2003, 07:21
Default A rotating solid domain in CFX551?
rotlin
I'm trying to build a rotating solid domain, how can I do this? is it possible in CFX551?
I tried to build all in one mesh group, but I could not define the rotating part.
I tried to build two "mesh only" dbs, one for the rotating solid, one for the fluid. Then I built a mesh import db and defined a sub-solid domain, but when I tried to write the def file, a message "there are no fluid regions" popped up. If I delete the subdomain, then it's OK without a solid defined.
Could anyone help me to solve this problem or give me some suggestions? Thanks!
If it's not possible in CFX551, would it be implemented in 5.6? (if anyone knows.)
Old   January 6, 2003, 19:52
Default Re: A rotating solid domain in CFX551?
Neale
What are you actually trying to do here:
1) Have a solid domain actually rotating along with a rotating fluid domain (attached to it) eg: a CHT blade inside a rotating reference frame.
2) A rotating solid domain which is attached to a stationary fluid domain and you want to model the effects of the rotating solid on the surrounding fluid including heat transfer to the CHT solid?
The modelling and setup approach is only slightly different for the two cases.
In both cases:
1) Import a grid with two 3D regions. 2) One 3D region is your fluid domain 3) The other 3D region is your solid (CHT) sub-domain
For case 1:
1) Define your fluid domain as a rotating reference frame and you are finished. 2) Define your CHT solid domain.
For case 2:
1) Define your fluid domain as stationary. 2) Define your CHT solid domain 3) Define the fluid side of your CHT domain interface to be moving at the specified velocity (you will have to use CEL expressions for the wall velocity to get it rotating).
Neale
Old   January 7, 2003, 05:59
rotlin
Mine is the 2nd case. I will try what you suggested. Thank you so much!
Vertical Axis Wind Turbine Rotating Domain Problems TWaung CFX 4 May 1, 2012 03:14
Monitor a point in a rotating domain taichijulie CFX 0 August 12, 2009 16:25
solid domain rotation!!!!! mehrdadeng CFX 4 May 5, 2009 15:22
[blockMesh] Solid volume inside computational domain francois OpenFOAM Meshing & Mesh Conversion 7 November 19, 2008 16:11
THERMAL CONDUCTIVITY FOR SOLID DOMAIN -BOUYANCY CARL CFX 1 June 9, 2006 16:44
