How to Add reactions!!
Old   January 7, 2003, 01:29
Default How to Add reactions!!
Devashish
Hello I want use one single phase reaction of Hydrogen i.e. H2 + 1/2 O2 -> H20 + 38.60 kmol/kg now tell me where i add this thing plz giude me
Devashish
Old   January 7, 2003, 03:26
Default Re: How to Add reactions!!
David
Tutorial 13 is a good example for reaction. Use CEL to compile your reaction and specify it in sub-domain.
David
Old   January 7, 2003, 09:00
Holidays
Set one up from the library that is available in Build for example; then edit the def file and modify accordingly.
If you are quite familiar with the code look for the REACTION file in CFX-5 installation, in the etc/ directory I think, copy and paste the mofified reaction(s) directly in the LIBRARY section of the def file (text edited).
particle surface reactions rati FLUENT 2 July 26, 2020 09:31
inconsistency in the chemical reactions in Reacting Foam? lfgmarc OpenFOAM Running, Solving & CFD 1 October 10, 2011 11:11
porous medium and reactions Valeria FLUENT 1 July 10, 2009 03:58
Solver problem with a big amount of reactions Leonid CFX 2 April 9, 2007 10:38
Add Measure Markings or Coordinates to the Contour Colin FLUENT 4 August 25, 2004 09:54
