Mass flow rate specification
Old   March 27, 2003, 08:23
Default Mass flow rate specification
Deborah
Hi all!
My geometry consists in a duct with inlet and outlet boudaries acting as periodic pair. In order to define the mass flow rate, I have create a sub-domain (which is the entire domain).For the source term I have the choice between "momentum", "mass source",... but not "mass flow rate". How can I do?
Thanks in advance.
Deborah
Old   March 28, 2003, 10:48
Default Re: Mass flow rate specification
Martin Bowers
Long way: Figure out what the correction distribution of momentum sources is to create the fully developed flow field I'm assuming you're looking for. For a straight pipe it's constant, anything else: probably not. You will have to find some way to iterate on the average value until you get the right mass flow rate.
Short way: Buy Fluent and just specify mass flow rate.
Future way: Maybe CFX will implement a periodic mass flow rate BC.
Old   March 30, 2003, 18:28
Hi Martin,
I think CFX4 has this type of boundary condition you describe. There is no need to go across to the dark side. Hopefully CFX5 will implement this type of BC in a future release.
Regards, Glenn Horrocks
Old   April 1, 2003, 02:00
Neale
This is certainly a non-trivial boundary condition to robustly implement in a coupled-implicit solver.
You could use a static pressure inlet and mass outlet, set the timestep small enough, and hope to hell things "hold on". It might work OK for an incompressible flow.
Neale.
Old   April 1, 2003, 13:59
Martin Bowers
Well I can appreciate that the BC might not be as easy to implement into a coupled implicit solver, but I haven't seen any justification as to why exactly.
If the implementation is just a matter of balancing a global source term against the desired mass flow rate, why does the user have to do that tedious iterative work when the code doesn't? - It is an iterative solver after all!
Particle Injection Mass Flow Rate and Position leonozx FLUENT 3 March 9, 2018 09:58
Mass flow rate at the outlet tejasvikrishna FLUENT 2 May 25, 2013 02:42
Mass flow rate sepidecent CFX 0 August 9, 2011 00:15
Mass Flow Rate is not converging destgir448 CFX 5 December 11, 2010 05:55
mass flow rate error Masood FLUENT 0 May 22, 2005 00:32
