Accelerating solid
Old   June 16, 2003, 09:49
Default Accelerating solid
blair
I would like to model a solid body that is accelerating through fluid. As far as I can make out the flow solver does not contain inertial terms and they need to be included seperately as a momentum source on the solid boundary. Is anyone able to help in this area?
blair
Old   June 16, 2003, 18:28
Default Re: Accelerating solid
Hi Blair,
What do you mean "inertial terms"? CFX solves the Navier Stokes equations, which will give you a friction force and pressure force on your body. These two forces should fully describe the forces on your body.
Regards, Glenn
Solid combustion problem.... godspeedsam FLUENT 3 May 24, 2022 04:29
How model radiation of both solid wall and fluid£¿ Harry Qiu FLUENT 2 February 3, 2013 23:04
Defining Solid Zones Not working elmcmaster FLUENT 3 May 22, 2009 07:14
Multiple Solid Domains - Interfaces Scott CFX 8 July 31, 2008 15:20
CFX4.3 -build analysis form Chie Min CFX 5 July 12, 2001 23:19
