sloshing
Old   March 13, 2004, 02:23
Default sloshing
Zaher
hi all, How can I model sloshing in CFX?
thanx in advance
Old   March 13, 2004, 15:39
Default Re: sloshing
Jeff
Set up two phases and use the free surface model.
Old   March 14, 2004, 05:39
Bob
You will also need to excite the fluid. To do this you will need to solve the simulation transiently and also need to move the body. The body movement will require the use of user fortran or you could wait till CFX5.7 where I think there is a GUI to do this (not 100% sure though !). Bob
Old   March 14, 2004, 16:33
Mesh movement was in the 5.7 beta so it should be in the erlease version. You could also excite it by moving the gravity vector and this would not require mesh movement.
Regards, Glenn
Old   March 18, 2004, 06:54
Bob
Hi Glenn we toyed with this but collegues were convinced that this would not give the same result. However we were looking at the added mass of the water, and I believe by changing the gravity vector, you do not include this ? Alas I'm no expert, and had to go by their advice ! what are your thoughts ? Bob
Old   March 18, 2004, 16:41
Hi Bob,
I can't see why for a simple horizontal oscillation changing the gravity vector would not work. You would need to be careful in considering which frame of reference the force/moments/velocity/displacements are in, nut as long as you have got your brain around that I can't see why it would not work.
Just my thoughts.
Glenn
Old   March 19, 2004, 17:29
Jeff
I've solved this very problem for a cylinder of water moving around a corner on a conveyor belt. We simply imparted an additional gravitational accelleration that changed direction with time as the centrifugal force was applied and then removed after the total travel time in the curve.
CFX takes care of the mass for you by imparting the body forces as long as buoyancy is on. You may want to make sure you set your reference density to that of the light phase (air above) which will deliver the appropriate hydrostatic head in the liquid.
I don't think there's a problem with this technique at all. And it is MUCH easier than moving the grid.
Jeff
Old   March 21, 2004, 23:26
Zaher
but how can I define the volume fraction of water and air inside the tank?? I don't have inlet or outlet.
Old   March 27, 2004, 17:02
Jeff
Using your initial conditions.
Use CEL to set the vf for liquid to 1.0 below a specified height (say z level) and 0.0 for everything above. Opposite for gas....
CEL EXPRESSIONS
z_inerface = 5.0 [in] # liquid level height
vf_liquid = step(z_interface-z)*1.0
vf_gas = 1.0 - vf_liquid END END
This sets liquide vol. frac. to 1.0 for all nodes below z_interface and 0.0 above interface. In your Initial Condition for Volume Fraction use the CEL variables vf_liquid and vf_gas.
Hope this helps, Jeff
Force Window and sloshing mass satellite_control FLOW-3D 0 October 6, 2011 09:04
Linear analytical solution oto the 2D free sloshing water surface elevation bearcat Main CFD Forum 7 August 5, 2011 20:13
Calculating Sloshing mass in a cylinder satellite_control FLOW-3D 0 June 20, 2011 05:34
Sloshing frequency determination alastormoody11 STAR-CCM+ 0 January 20, 2011 22:40
Udf for sloshing problem D.Martelli Fluent UDF and Scheme Programming 0 December 9, 2009 11:21
