Export data from several .res files
Old   April 13, 2004, 20:02
Default Export data from several .res files
Nessan
Hello, friends,
Someone asked a question about making animation from several .res files. My question is how to export the data from several files. I mean how to export pressure and velocity, for example, on a line from several .res or .trn files. I tried using scripts but it did not export any data at all. I used Batch mode CFX-Post.
Anybody has experience on that, please give me some hints.
Thanks,
Ndssan
Old   April 14, 2004, 09:12
Default Re: Export data from several .res files
Gloria Gaynor
If you use Unix(linux,solaris,etc...) and you know a little of csh or sh scripting this can be done very easily. Then you'll combine an unix script with the batch file of post to get your files.
Old   April 14, 2004, 12:56
Robin
Nessan,
-Launch Post. -Create a new session file and begin recording. -Open one of your res files. -Create the line object to export data on. -Export the data you want on the line. -Stop recording the session file.
Now, open the session file in a text editor. All your actions and relevent objects will be in that session file. Put a Perl loop around the whole thing and you can load multiple files, writing a new export for each.
For more information on Perl, go to http://www.perldoc.com/.
Regards, Robin
OpenFOAM15 paraFoam bug koen OpenFOAM Bugs 19 June 30, 2009 10:46
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
Export of data at cells from Fluent. Mark FLUENT 2 July 29, 2008 04:11
batch process- export data Grace FLUENT 0 May 15, 2006 20:14
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
