model for porous material
Old   October 13, 2004, 13:38
Default model for porous material
sleepinglily
I am new to CFX and I want to model air flow thru porous material, I do not know how to do it, can somebody provide me an example to handle the porous material? I saw some old post mentioned about the CFX community has an example, but I do not have a login name for that.
many many thanks!
Old   October 14, 2004, 23:07
Default Re: model for porous material
Anurag
we need to have a subdomain to define porous media. this subdomain is the 3D region which is supposed to be a porous media. properties of porous media is defined as momentum source. Different options are available (permeability, linear and quadratic resistance coefficients). in CFX 5.7 you can also specify anisotropic resistance in specific direction. contact CCFX tech support for user ID & password.
Old   October 14, 2004, 23:57
sleepinglily
Thank you very much for you reply. I do not have CFX yet, I need to know CFX can do the model of air flow thru Carbon foam heatsink before I talked to my boss to let him buy it. so I cannot have userid & password to that tutorial. Can I send you emails to you to ask questions?
Old   October 19, 2004, 10:45
Amir
Hi All, I have gone through the porous medium abilities of CFX but I still have problem in defining C1 and C2 as explained in http://www-waterloo.ansys.com/cfxcom...a_in_cfx-5.htm I can't figure out why it's mentioned that we should devide the resistance coefficients by porosity. The Darsy equation is developed based on superficial velocity and as they claim, CFX use superficial velocities for porous medium too during the run so why we should devide C1 and C2 by porosity? thanks for the help Amir
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 40 January 27, 2023 07:18
VOF plus Solidification/melting model kql FLUENT 3 April 29, 2014 16:50
New implemented algebraic Reynolds stress model volker OpenFOAM 13 October 21, 2013 00:01
Material - new mixture model Munir Ahmed Khan FLUENT 0 July 3, 2008 11:24
DPM model w/ Wave model - errors in documentation HS FLUENT 0 April 12, 2006 04:37
