Automatic post processing of Transient simulation |
June 24, 2005, 04:47 |
Hello
I have been trying to do some post processing calculation for my transient simulation. I have done this per hand very often but now i want it to be automatic so that i can use it for optimization process. My query is: I want to calculate the total energy at the inlet and outlet of the nozzle which is time dependent. I used to write density, pressure and velocity at the inlet and outlet by exporting the values from chart in CFX-Post and than in Excel i did further calculation to find the nozzle efficiency in transient flow. Any one know how can you use command editor in CFX-Post to store and calculate the sum of energy over time. Just for reference the equations are like that: Efficiency = Numerator / Denomenator Numerator = Sum((Pressure * Velocity * Area)@outlet*DeltaT)+Sum((0.5*density*Area*Velocit y^3)@outlet Denomerator = should be same as Numerator but calcualted for inlet thanks Aziz |
June 24, 2005, 12:34 |
Re: Automatic post processing of Transient simulat
Can't you do that with CEL expressions? What does Sum mean? Summation over the area, or over the time?What does DeltaT mean? Does T stand dor time or for temperature? Rui |
June 24, 2005, 14:37 |
Refer to CEL user manual and then use PERL language for the programming syntax under command editor. It's pretty simple (I only spend one week to learn PERL and I can automate basically anything in Post now). There're quite some free references about PERL programming on Google.
Cheers. |
Ansys Post processing | ano999 | ANSYS | 1 | May 27, 2011 16:24 |
NO model vs post processing in coal combustion,CFX | sakalido | CFX | 1 | April 15, 2011 14:07 |
a transient simulation question | rystokes | CFX | 3 | June 3, 2009 07:44 |
Steady-state simulation to start a transient simulation | smagmon | CFX | 2 | May 18, 2009 03:59 |
post processing in CFD | MANISH BHARGAVA | Main CFD Forum | 0 | October 17, 1998 20:51 |
