Windows Batch Question
Old   September 1, 2005, 18:14
Default Windows Batch Question
Joe
I would like to submit a batch job for multiple cfx5 runs. I have read the threads on this, but am unable to run.
Before running the batch file I wanted to test it out for a single run on the command line. I modified the path to include the bin directory. When I issue: cfx5solve -batch -def filename.def I get the response tha cfx5solve is not a recognized command.
Any idea what I am missing?
Thanks Joe
Old   September 1, 2005, 18:44
Default Re: Windows Batch Question
You don't need the -batch option. Use cfx5solve -def file.def. Also, if you use the command line generated from the launcher it already knows the path to the CFX executables so you don't need to modify the path to find the CFX executables.
Old   September 2, 2005, 00:30
test
If you have modified the path to the bim folder the command should be executed as:
./cfx5solve
instead of just
cfx5solve
Also as indictaed you need not use "-batch"
Regards, test
Old   September 6, 2005, 14:22
Joe
Thanks for the help.
At a windows command prompt I typed in the command as suggested. cfx starts, but exits with error after less than a minute. A .out file is written that contains the following:
The CFX-5 solver has terminated without writing a results file. Command on host joe2k2 exited with return code 0.
The c++ debuger mentions something about solver-pvm.exe. Any idea what corrections are needed? Is there any documentation on the error codes.
Thanks Joe
to run a replayfile in batch mode from UNIX froztbear ANSYS Meshing & Geometry 4 May 13, 2014 08:00
Unanswered question niklas OpenFOAM 2 July 31, 2013 16:03
Windows to Linux => END problems... zboud CFX 4 February 4, 2010 16:53
Cross-compiling OpenFOAM 1.6 on Linux for Windows 32 and 64bits with Mingw-w64 wyldckat OpenFOAM Announcements from Other Sources 7 January 19, 2010 15:39
question K.L.Huang Siemens 1 March 29, 2000 04:57
