Mesh from finished FSI to CFX Pre?
Old   December 1, 2013, 12:21
Default Mesh from finished FSI to CFX Pre?
Lukasz
Luk_Fiz is on a distinguished road
Hi all,
I have question addressed rather to simulation methodology but maybe there is some simple technical trick I am not aware of.
The problem is like this:
- I perform 2 way FSI in which fluid flow deforms domain. Couple of troubles but ok in general,
- after finishing first stage I want to "save" deformed mesh and use it as an input to new calculation NON FSI (simple CFD in CFX). I want to do this to study some effects that has little influence on deformation (so solid solver is not necessary, and it would be much faster not to use them).
Here is the question: is it possible to "export" deformed mesh (from Post?) and use it to simple "static" calculation in Pre?
Thanks,
Luk
Luk_Fiz is offline   Reply With Quote
Old   December 2, 2013, 02:16
Lance
Lance is on a distinguished road
No need for Post. In Pre: Import mesh/"Files of type: CFX-Solver Input" and chose your FSI results file.
Lance is offline   Reply With Quote
Old   December 2, 2013, 02:54
Lukasz
Lance, thanks for quick answer. You save tons of time for me
(I just KNEW that there must be such option but stuck in "Exporting Mesh Deformation" blablabla. Why most obvious things are most difficult to find?)
Thanks again,
Luk
3D Hybrid Mesh Errors DarrenC ANSYS Meshing & Geometry 11 August 5, 2013 06:42
CFX Oscillating Cylinder FSI Problem vplpaul CFX 1 July 23, 2013 16:43
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
running 2D airfoil mesh in CFX iffy ANSYS 1 February 13, 2011 21:35
CFX mesh & ICEM mike CFX 3 April 27, 2006 15:27
