how to calculate prssure force & lift force in CFX
Old   March 2, 2006, 23:18
Default how to calculate prssure force & lift force in CFX
zaidun
hi, i'm zaidun from malaysia if somebody can help me in calculating pressure force leading to lift and drag of wing or surface in CFX 10.. I dont really understand macro capabilities in CFX 10.. i'm currently doing aerodunamics analysis on aircraft
if someone really need give hand, just email me at zaidun_muhammad@yahoo.com
Old   March 3, 2006, 05:53
Default Re: how to calculate prssure force & lift force in
Jim
You need to use the quantitative tab in the post processor. You can either use the force function, or area integrate the pressure and wall shear stress. Both are a bit woolly because the direction of the resultant force is not obvious. Good luck!
Old   March 10, 2006, 21:04
zaidun
thanx a lot jim, i'm really appreciate it.. i'll it.. thanx
Old   March 27, 2006, 10:17
baddesuribabu
sir iam also doing same problem here if u have any idea please send to me
Old   March 28, 2006, 02:06
andy hou
sir I am also doing same problem here if you have any idea please send to me
how does Fluent calculate the pressure and viscous force ? e30.lsb FLUENT 7 June 27, 2011 21:31
How does FLUENT calculate lift and drag? xTamx420 FLUENT 0 May 30, 2011 13:35
Calculate Drag force for flat plate vsun FLUENT 0 October 3, 2010 07:56
Lift force in 2D axisymmetric in N/rad or N/m? Dallas56 FLUENT 0 May 12, 2010 02:41
Lift force or coefficient of lift Rola FLUENT 1 November 12, 2006 13:29
