pls help fluctuating residuals due to courant no
Old   March 27, 2006, 05:09
Default pls help fluctuating residuals due to courant no
sagar
Hi to all, i have some query about courant number.because i am getting fluctuating residuals in my problem. (1) what should be the limit of courant number (Max courant no or rms courant no) for feasible solution. I have done several tries for one prblem by changing mesh sizes.and mesh type.(tet and hex mesh).In tet mesh i have got higher courant number than hex mesh.so i have query that what shoud be the limit of courant no. to get feasible solution. (2) Suppose residuals are getting fluctuating then is it problem with meshing or wrong turbulence model?or is it due to courant number very high.? (3) Does courant no. depend on mesh? (4) I have also got courant no. upto 245 (max courant no.)in one problem.is it right?in that still solution is converging.so can i put confidence in that result?
Thanks all.
Old   March 27, 2006, 06:21
Default Re: pls help fluctuating residuals due to courant
James Date
You must reduce the time step so the courant number is less than 1 (MAX Courant) if you really want to capture the true transient behaviour in the flow, anything else will give you the wrong answer! Unless you are time stepping to a steady state solution that is!
Old   March 27, 2006, 09:32
TB
There is a discussion about significance of CFL in community forum. CFL < 1 is a condition for explicit transient scheme. CFX used implicit approach for calculation of transient term. It's possible to get an accurate solution with CFL higher than 1.
CFL of 254 seems to be very high. Try to reduce your timestep and get CFL within 10-20.
Old   March 28, 2006, 01:10
sagar.
Thanks james and TB for ur suggestions.
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
fluctuating residuals shilpamkar FLUENT 0 August 2, 2011 01:57
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
Convergence - scaled vs unscaled residuals HS FLUENT 1 November 7, 2005 05:45
