May 21, 2006, 13:09 |
Drag Coefficient
Hi, there!
I'm a new usser of the CFX 10.0. I'm working at EADS Aerodynamics Department. And I'd like to know how can I get the CD with CFX 10.0. Or I'd like to know how can I do it with Ensight 8.0, thanks! |
May 23, 2006, 08:19 |
Re: Drag Coefficient
Hi...I think you ahve to know the drag force, dynamic pressure and reference area to calculate the drag coefficient. You can calculate dynamic pressure as = 0.5*density*velocity*velocity and Reference area depends on the geometric model. CFX witll give you drag force value. Go to POST, Load the result file, click the calculator, choose "force", select the direction of drag (x,y or z), choose the surface of the geometry on which drag has to be calculated and thats it. click "calculate". It will give the drag value... Regards, VVJ.
May 23, 2006, 08:23 |
Hello Julian, I am would like to be your friend. I am working on the drag reduction problem. I am working as project trainee in Indian Institute of Science- Bangalore (Inda). I am an Indian. If you are interested, then please mail me. My mail-id is vijeshjoshi23@yahoo.co.in Regards, VVJ
May 23, 2006, 15:05 |
Thanks a lot, your advise was very usefull.
Take care! |
May 23, 2006, 17:45 |
i am working also on drag reduction meaby i can be your friend too? i try to reduce the drag of a rotating wheel
May 23, 2006, 23:55 |
Hi Klaas, feeling very happy to be your friend. You said your problem is to reduce the drag on a rotating wheel. Can you please elaborate on rotating wheel. Is there any friction or something? With the drag value on this wheel, what further studies will be done? Please let me know. Regards, VVJ.
May 24, 2006, 05:50 |
well i try to determine the lowest drag in form and there is no other friction then air so it must be in the form and the ideal in differant angle´s
as well a disc wheel as a spoked wheel we are talking about a bike wheel |
May 25, 2006, 01:50 |
Hi Klaas, I have not worked on form drag problems. I dont have much knowledge in this problem. Anyhow , I will work on this after some time. Presently I have exams. I will mail you again. Regards, VVJ
May 25, 2006, 07:40 |
#9 |
thanks
Drag Coefficient Convergence Problem | John | FLUENT | 18 | June 24, 2023 09:22 |
drag coefficient in ansys fluent 12.0 | krishna | FLUENT | 19 | April 12, 2018 00:49 |
Incorrect Drag and Drag Coefficient for flow over a cylinder | ozzythewise | Main CFD Forum | 8 | June 13, 2012 06:24 |
Drag coefficient for parcels in dieselFoam | sebastian_vogl | OpenFOAM Running, Solving & CFD | 5 | December 31, 2008 12:19 |
Automotive test case | vinz | OpenFOAM Running, Solving & CFD | 98 | October 27, 2008 08:43 |
