Icemcfd cannot keyin values in Centos4.4?
Old   March 26, 2007, 11:10
Default Icemcfd cannot keyin values in Centos4.4?
Tina
Hi all, I just installed icemcfd v10 in CentOS4.4 system , I can start icemcfd properly, but as I try to type in values (or texts)in icemcfd text field, then it seems that the keyboard not responding, I cannot type in any letter or number!!
My PC is IBM T40 .
Does anyone know the reason? or any solutions?
Thanks in advance
Tina
Old   March 26, 2007, 11:14
Default Re: Icemcfd cannot keyin values in Centos4.4?
Joe
Is this happening in workbench on icemcfd standalone?
Old   March 26, 2007, 11:20
Tina
thanks, it's happened in icemcfd standalone
Old   March 26, 2007, 11:30
Joe
Are you running the 64bit version of centos?
Old   March 26, 2007, 21:16
Tina
Thanks for your reply.
No, it's 32bit version of CentOS . The icemcfd can start correctly, can mesh, can import ...., just cannot type in any letter or number in text field!
Even in my other PC(Desktop and laptop ) , all encountered the same situation.
Old   March 27, 2007, 09:38
Joe
I also noticed this problem in Icemcfd but only in Workbench mode (RHEL 4.4 64 bit). Standalone works fine.
I dont have a solution. Perhaps its related to the LANG setting.
Old   March 27, 2007, 10:24
Tina
OK, thanks anyway.
Old   April 2, 2007, 23:24
Default OK, I found the reason!
Tina
Yes, Joe , you're right!!! If I changed the LANG to English , then it's OK now! THANKS
Regards, Tina.
Old   April 3, 2007, 06:19
Default Re: OK, I found the reason!
Joe
Which LANG string exactly did you use?
Old   April 4, 2007, 09:54
Tina
Joe, thanks for your help! I've done many trings:
1. I use zh_TW, it fails! 2. I switch to zh_CN, it works! 3. I switch to en_US, it works!
and I also found that, I don't need to boot system in en_US. I still boot Linux in zh_TW. but I just set environment variables before I execute icemcfd (sounds easier for me)
The exact steps of my doing is: (I'm in Ubuntu Linux OS) 1. add these two lines in /etc/environment
LANG="en_US.UTF-8" LANGUAGE="en_US:en"
and mark out the original lines #LANG="zh_TW.UTF-8" #LANGUAGE="zh_TW:zh"
2. every time I want to execute icemcfd :I just
$ source /etc/environment
3. then
$ icemcfd -cfx perfect to work!
Old   April 4, 2007, 10:00
Default Further notes on other Linux distr.
  #11
Tina
And furthermore, I've tried many Linux distributions RHEL 4.x SuSe10 CenTOS 4.x Fedora Core 6.x Ubuntu 6.10
All have the same problems in zh_TW LANG ! But this is the way to overcome !
Old   April 5, 2007, 10:59
Default Another easier method
  #12
Tina
Another method,
before executing icemcfd , just
$ export LANG='en_US.UTF-8'
then it works also!
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
max node values exceed max element values in contour plot jason_t FLUENT 0 August 19, 2009 11:32
exact face values RubenG Main CFD Forum 0 June 22, 2009 11:09
strange node values @ solid/fluid interface - help JB FLUENT 2 November 1, 2008 12:04
IcemCFD 4CFX-How to fix domain Ahmed CFX 6 March 9, 2004 18:38
