July 7, 2007, 09:02 |
Negative volume in mesh motion
Dear Friends
I was solving a moving mesh problem like check valve.y negative volume occurs reason? ERROR #002100012 has occurred in subroutine cVolSec. Message: A negative ELEMENT volume has been detected. This is a fatal error and execution will be terminated. The location of the first negative volume is reported below. Volume : -0.4107E-13 | Location : ( -0.35156E-02, 0.36065E-01, -0.49511E-03) |
July 7, 2007, 11:16 |
Re: Negative volume in mesh motion
Hello. That error is very common when you try to deform a domain. There is no easy answer. The first thing you may do is to identify the small mesh elements in your domain with volume negative (they are so small that were reverse like a t-shirt that you just take off...) try to use planes and volume regions (with "draw lines" active) to locate such elements. Once you know approximately the location, you may have to modify the mesh stiffness equation in order to get a better node displacement when deforming the mesh and check the new elements status (try a mesh stiffness equation: 1 [m^3 s^-1]/Wall Distance; or 1 [m^5 s^-1]/Volume of Finite Volumes). You also may check the surface displacement after deformation, it may be doing a impossible movement. I hope this lines gives you an idea. Good Luck.
July 9, 2007, 00:24 |
Thanks dude
Can u tell me why negative volume occurs ? |
July 10, 2007, 23:53 |
I have find out the reason for negative volume
F=ma m-mass of the ball,a=acceleration of ball F=force of the flow. since i have specified only the force of flow and no other opposing force like spring or gravity force.My ball is hiting the wall in first iteration itself and stops saying negative volume.In post the wall bulges. Can anyone tell how to stop the ball before it reaches the wall. |
July 11, 2007, 18:31 |
Negative volume errors occur when an element is turned inside out due to the mesh motion. You need to check your motion equations and possibly use a finer timestep. Glenn Horrocks |
July 11, 2007, 23:51 |
Hi
My problems is I have flow force only and no other force opposing the flow force. I want to stop the ball before the ball goes and hit the wall. Is there any eqn to resist the motion of the ball only to a certain displacement. |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Dynamic mesh, negative volume, help! | vboris | FLUENT | 0 | February 23, 2011 17:19 |
engrid: Internal volume mesh becoming coarser during boundayr layer addition | Arnoldinho | OpenFOAM | 1 | January 22, 2011 04:31 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
