multiphase problem having oil droplets
Old   March 5, 2008, 15:21
Default multiphase problem having oil droplets
Kushagra Mittal
What multiphase models in CFX-11 should I think of to simulate deoiling hydrocyclones? The feed water will have different size of oil droplets.
Some one has suggested me to use MUSIG model but I am wondering what might be other choices, if any? And what are the challenges, difficulties, or merits of MUSIG in CFX?
Thanks a ton for sharing your experience with me.
Kushagra
Old   March 5, 2008, 16:35
Default Re: multiphase problem having oil droplets
Is a lagrangian model appropriate? If it is then you can model the droplets as whatever size distribution you like.
Old   March 5, 2008, 16:42
KK
Thanks Glenn, But I think Lagrangian will not include coalsence and breakup of oil droplets.
By the way, I was using Lagrangian for solid particle tracking after my fluid flow field was establsihed. But very surprisingly, all the particles were reported at the bottom outlet of my hydrocyclone. (even for the particles of 4 microns.)
Do you have any idea why it might be happening? Is it possible because I am not including solid-solid interactions ? Other people have simulated the same in FLUENT with one way coupling and it gave them good results.
THanks very much. :_)
Oil combustion problem brajh11 CFX 1 December 7, 2012 01:49
multiphase steady problem lionlove0903 OpenFOAM Running, Solving & CFD 0 January 19, 2011 03:49
gas-liquid-liquid multiphase problem suiger CFX 0 December 11, 2010 04:16
Multiphase radiation in Ansys 10 problem Luk CFX 2 June 5, 2008 11:31
CF4 - need advice on setting up multiphase problem Brett Towler CFX 2 August 18, 2000 16:38
